lt1 fluid capacties
Old Jun 6, 2004 | 09:19 PM
unvc92camarors's Avatar
lt1 fluid capacties
got my 95 z about 2 weeks ago i guess and i can't stop grinning
but anyways, i want to replace all the fluids, do a tuneup, etc. to make sure she's running right before i do some mods
i did a search and didn't come up with anything so...
here's my questions
how much coolant do i need to buy? also, any specific kind to look for?
how much dexron3 at fluid do i need to fill my manual tranny?
how much brake fluid?
how much power steering fluid? any specific kind to look for?
does ac delco make fuel filters and pcv valves? if so, anybody got some part #'s?
edit: oil too i suppose, i heard mobil 1 synthetic is pretty top notch, figure i'll give it a shot, what kind? 5w-30? 10w30?
i guess that's about it
i think i have all my other stuff already figured out and lined up
thanks in advance
Old Jun 6, 2004 | 10:00 PM
Many of those questions can be answered by your owner's manual.
Old Jun 6, 2004 | 10:03 PM
Super Slow '97's Avatar
If you check your owners manual there is a section labled capacities it should have all the info that you need. Yes the Mobil 1is the best that is all I use 10W-30 should be fine. also Shoebox has the capacities on his site http://shbox.com/pdf/manuals.html click on the manual for the 95 then go to the index to find the capacities
-Matt
Old Jun 6, 2004 | 10:24 PM
yea, i found it confusing there for a second
i think i got most of it now
the only things it doesnt mention are power steering and brake fluid
it says what to use but not how much i need
any help in that is greatly appreciated
thanks shoebox and super slow 97
Old Jun 6, 2004 | 10:52 PM
Spinner's Avatar
A quart of brake fluid should be enough. Possibly closer to 2 quarts of PS
Old Jun 7, 2004 | 01:33 AM
bozobuttz's Avatar
You should get a gallon of transmission fluid. A quart of power steering fluid should be enough. I recommend Valvoline Maxlife power steering fluid. If you need any advice on how to flush it properly, PM me. Dont forget to change the differential fluid too. You'll need 2 quarts plus the GM additive if you have a posi diff, and a gasket plus some RTV sealant.
Old Jun 7, 2004 | 07:21 AM
if i need a gallon of tranny fluid, how come it says 8pts in the book?
course, i don't know, 8pts might equal a gallon, it's been a while since i converted anything
thanks bozobuttz and spinner for the info though
and bozo, yea i already got the diffy fluid
PCLZ28
Dec 24, 2015 05:19 PM
jb4xx
Feb 2, 2015 10:00 PM
ro2207
Dec 4, 2014 06:18 PM
Nostang 96z
Sep 10, 2002 08:54 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
