LT1 Flexplate question, please help!!!!!!
Old Apr 25, 2019 | 12:12 AM
  #16
1320SiN's Avatar
Re: LT1 Flexplate question, please help!!!!!!
Originally Posted by matLT1
I wouldn't think it is due to your flexplate swap. The reason I say this is because these engines are internally balanced, meaning the flywheel and balancer don't have a role in balancing the crank. Unlike some of the older engines like 454's and 400's that were externally balanced that did rely on the flywheel and balancer. I would check the flywheel to make sure it isn't warped, some companies will ship them that way once in a while. Also, did you use an alignment tool when you installed you clutch? And does it vibrate when you rev it while the car is parked or is this only while you are driving?
that is wrong the front half of crank is balanced but the back is not because of the 1 piece rear seal design but u can buy just a weight that goes on crank before flywheel it only goes on one way cant get it wrong and can be used with at or mt.
Old Apr 25, 2019 | 12:14 AM
  #17
1320SiN's Avatar
Meat Spinn
Sep 24, 2009 05:13 PM
Rising Phoenix
May 3, 2008 09:26 AM
jclark311
Mar 18, 2007 09:43 PM
IdahoLT1
Mar 12, 2006 01:38 PM
