LT1 Electric waterpump guys
Old Apr 19, 2015 | 06:40 PM
Stay Puft's Avatar
What size belt do you run? I bought the car that came with an electric water pump and it seriously looks like the Belt they used is too long and is loose.
Old Apr 19, 2015 | 07:45 PM
Re: LT1 Electric waterpump guys
The stock water pump is not run by the serpentine belt, its gear driven off a gear on the back of the cam sprocket.
Either the stock belt has stretched, someone replaced the stocker with a too long belt, or the tensioner pulley is worn out.
Old Apr 20, 2015 | 08:04 AM
Strick's Avatar
Just so you are not confused, the LT1 does not use a belt. The pump is driven by the cam by way of a shaft.
Old Apr 20, 2015 | 04:27 PM
What did you find confusing in my explanation?
Old Apr 20, 2015 | 06:24 PM
Strick's Avatar
Absolutely nothing. I just didn't read yours. I just jumped on an answer, sorry.
97z28k&N
Jan 9, 2015 04:58 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
Red97LT1
Aug 7, 2002 05:45 PM
