LT1 Dies and will not start
Old Nov 30, 2009 | 02:34 PM
  #16
Guest47904's Avatar
Guest
Here's one:
http://www.aldlcable.com/
or these:
http://akmcables.com/ic.htm
However I think this will do what you need
http://www.auto-repair-manuals.com/A...Scan-Tool.html
And is even available at Sears
http://www.sears.com/shc/s/p_10153_1...0070515x00001c
Old Nov 30, 2009 | 10:59 PM
  #17
Originally Posted by 1994z28ss
So by the way my tach is jumping around with the key on. The only culprits could be the Opti of PCM, and from what i have been researching these PCMs just dont go bad, so the opti is my problem?
Clarity isn't your strong point, but are you saying that your tach needle is jumping around when the key is in the "on" position, but the engine is not running?
Old Dec 1, 2009 | 05:30 AM
  #18
Guest47904's Avatar
Guest
Bad battery connections can do that
So by the way my tach is jumping around with the key on. so the opti is my problem?
My P/up did that when I had a bad connection at the battery. Particularly when it was cold out. Only did when the engine should have been cranking but did not rotate with the key in the start position.
Old Dec 2, 2009 | 07:52 AM
  #19
1994z28ss's Avatar
Sorry for my clarity, but what i meant was with Key On Engine off, Key in the run position not start. The tach will jump from 0-2000 and everything in between very erratically.
Old Dec 2, 2009 | 07:54 AM
  #20
1994z28ss's Avatar
Thnks for the information speedy and as soon as i can buy/borrow a scanner will read the codes and let you know.
bfmv13trivium
Jan 14, 2015 09:57 AM
A's 91 Z28
Jan 11, 2015 10:58 AM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
