LT1 Crankshaft Hub
Old Sep 17, 2010 | 01:35 PM
dalynchmob's Avatar
LT1 Crankshaft Hub
Planning on fixing this timing cover oil leak finally. Was going to replace the crankshaft hub since i think one of the ears on it has been slightly bent for the last 30k miles. Can't seem to find the stock style three eared one anywhere. Anyone have any suggestions on a good hub? Not talking the most expensive just a mid level one. Thanks
Old Sep 17, 2010 | 04:06 PM
NightShadeZ28's Avatar
I would not go with anything other than ati. You definitely do not want a underdrive hub and most others out there are junk.
Old Sep 17, 2010 | 04:14 PM
If I'm reading his post correctly, he just wants a replacement hub, not a complete damper/pulley assembly.
Check Thunder Racing. I believe they sell keyed hubs. You don't have to use the key. $85 though.
http://www.thunderracing.com/shop-by...ankshaft-Hubs/
Old Sep 17, 2010 | 04:57 PM
dalynchmob's Avatar
The 94s don't use keyed hubs? They just press on there in no particular orientation other than straight on? Yes injuneer i have a fairly new (1 yr old) stock damper.
The ones from thunder racing bolt right up to the stock damper?
Old Sep 17, 2010 | 05:32 PM
RamAir95TA's Avatar
The factory hub is not keyed on all LT1s. It is only press-fit.
Old Sep 17, 2010 | 06:30 PM
dalynchmob's Avatar
Now wheres that dam easy button at?
Old Sep 24, 2010 | 10:35 AM
ToocoolZ28's Avatar
So to make sure I understand this, it doesnt matter how it goes on? No orientation to worry about?
Ron
Old Sep 24, 2010 | 11:14 AM
Z28SORR's Avatar
There all over E-Bay. Just got a new one from there yesterday.
Old Sep 24, 2010 | 11:18 AM
RamAir95TA's Avatar
Ron
If you look at the damper, there is a cast arrow. It is there for timing purposes (finding TDC, etc), but in no way is it absolutely necessary to keep it in any particular orientation.
Old Sep 24, 2010 | 01:16 PM
ToocoolZ28's Avatar
Thanks, I needed to know that. The last time I changed my opti I was going to change the timing gear set too but I couldnt figure out how to get the hub back on in the same place if I took it off, so I didnt change them.
What the heck, it only has 260,000 miles on it, should be good for another few thousand.
Ron
Old Sep 24, 2010 | 01:50 PM
Sorry I did not read the question. I agree with all of the above.
HectorM52
Jul 30, 2017 11:46 AM
cyteone
Feb 7, 2015 06:04 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
1LEThumper
Jul 14, 2003 12:45 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
