lt1 cams
Old Apr 16, 2008 | 06:55 PM
  #16
LSWHO's Avatar
Originally Posted by SS MPSTR
sound intimidating, but run like a turd? uh, okay. don't pick a race with an evo.
Check out the second post on this thread:
http://web.camaross.com/forums/showt...ghlight=gm+847
This guy is a local and his car is VERY stout. My brother can personally attest to this.
It may not see full potential without heads, but it'll still put good power down.
Old Apr 16, 2008 | 08:57 PM
  #17
SS MPSTR's Avatar
https://www.camaroz28.com/forums/sho...ghlight=gm+847
contrary to what he says, the larger valves and increased compression makes a pretty big difference.
Old Apr 16, 2008 | 09:53 PM
  #18
speed_demon24's Avatar
As do the STD #'s instead of SAE #'s.
  #19
LSWHO's Avatar
Yes, but even if that gave the car 20hp that's STILL 350whp. And still not much curve to the torque. It, to me, still makes better power than a smaller cam. It just has potential to make MORE.
I believe SAE was 371 and STD was 378.
And on top of that Brain dynoed 358whp GM 847 with the heads having NEVER BEEN REMOVED, and the graph otherwise looks the same, just slightly lower.
Old May 16, 2008 | 06:36 PM
  #20
fireman's Avatar
barely over 1/2 point bump in compression and 1.98/1.55 valves equals a "pretty big" difference?
Old May 17, 2008 | 07:47 AM
  #21
ghost97ta's Avatar
cam
i put a comp 304-8 in my car it sounds better then stock works well
with stock motor has a nice lope it is on a 114 lobe center intake lift @.50
is .500 exhaust lift is 510 and i have a flow master 3in cat back and it sounds great .
rideordie
Nov 5, 2019 04:52 PM
oldschool
Feb 9, 2016 09:21 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Queens94z28
Nov 20, 2014 06:03 PM
