Spark Plug Question
Old May 17, 2008 | 12:03 AM
BMD18's Avatar
Spark Plug Question
Hey i had a question for who ever has the answer! I need to know an easier way to take out the passenger side!! I have to put plugs and plug wires in!! I was just wondering whats the best way!!!!!
Old May 17, 2008 | 12:10 AM
mrmint69's Avatar
I think removing the starter and doing it from below works for some. Get headers and it will be much easier.
Old May 17, 2008 | 04:23 AM
MARKTHOMASBRAND's Avatar
I did all my plugs on the passenger side from the top,managed to do them without removing anything else
Old May 17, 2008 | 07:24 AM
There is no easy way.
Old May 17, 2008 | 08:11 AM
That's very true,it helps if you have long skinny arms,unfortunately I don't .
I found the one at the back to be the hardest.Some of them can be done with an open-ended wrench directly onto the spark plug socket,others can be done with a ratchet.
The plug wires aren't quite as bad,cut the boots off the end of the old wires and then you can pull them through the looms.I routed my new 8.5mm wires behind the power steering pump on the passenger side and used plenty of plastic cable ties to keep them away from my stock manifolds.No problems in over a year now .
Regards,Mark.
mritter1965
Feb 9, 2015 07:01 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
