lt1 cams
Old Apr 15, 2008 | 08:59 PM
thedude412's Avatar
lt1 cams
whats the biggest cam i can put in a stock lt1 with longtube headers????
Old Apr 15, 2008 | 09:28 PM
94zgreenmachine's Avatar
Why do you ask the "biggest" ? What are you really looking for? Just stuffing the biggest cam you can find into your motor is not the right way to go. Explain what you want, your budget and where you are at, with your car, to this point.
Old Apr 15, 2008 | 10:35 PM
thedude412's Avatar
i want sound and intimidation.the car is a stock lt1 camaro i just got and want to make sound like a beast for now i don't know much about lt1s.i got a big block for it next year.
Old Apr 15, 2008 | 11:49 PM
69z-28's Avatar
dont put a big block in the car. you can build a helluva LT1 for cheap and it would actually fit and drive properly. biggest cam i would go in a stock LT1 would be along the lines of a GM847, much bigger and you'll be experiencing losses instead of gains. keep in mind, with stock heads, cams much bigger than mid 230's at .05 dur are gonna be choking. also you will need the entire supporting valvetrain. if you just want it to sound nice and add a bit of power, toss in a hotcam kit for 700 bucks, change the timing chain and call it a day. you can even run it on a stock tune. otherwise, toss the biggest cam you can find in it and wish you never did..... bigger is not always better.
Old Apr 15, 2008 | 11:54 PM
Rising Phoenix's Avatar
/thread
Old Apr 15, 2008 | 11:59 PM
derbs's Avatar
I'm going with the comp cams 306 1.6 rrs crane springs comp pushrods and ls7 lifters with stock heads and 32 pound injectors with long tubes and a tune I've herd nothing but good things with that cam.
Old Apr 16, 2008 | 04:12 AM
red1984's Avatar
I think that the cc306 is to big of a cam with stock heads. You would need to have then ported to get the full potentual out of it. If I were you I would go with the cc503. It is the biggest you would want to go with stock castings and would make good power. What r your goals. Just my 2cents.
Old Apr 16, 2008 | 10:00 AM
SS MPSTR's Avatar
sound intimidating, but run like a turd? uh, okay. don't pick a race with an evo.
Old Apr 16, 2008 | 10:23 AM
jasonisdn's Avatar
i know of someone who makes cams like that. LOL
Old Apr 16, 2008 | 11:17 AM
thedude412's Avatar
the car is not a race car this year i just want it to sound like one.i got a 540ci big block for it to be a race car.but that is for next year.i need to know what cam is the best sounding for a stock lt1 with longtube headers.
Old Apr 16, 2008 | 12:30 PM
derbs's Avatar
Ill be getting heads soon after its all put in I've herd of many people running the cc306 with stock heads.
Old Apr 16, 2008 | 01:18 PM
DAVE00's Avatar
Stock heads (unless with a good port job) are going to limit your setup with this cam as the CC306 is probably too big for your setup. Also, keep in mind that you are going to need a good tune as it will run like crap without one. You will probably have losses and not make much power at all!!! Lastly, I don' t know where you live but if you are in an area where there is emission testing/sniffing this cam is hard to get to pass the tailpipe sniffer test and some have said it takes a very good tune to get it to pass. If you have stock internals and programming I'd recc sticking with the GM847, Hotcam or the CC305 as these will give you good power without the problems you will probably have with the CC306. Just my 2 cents.
Old Apr 16, 2008 | 06:07 PM
If you just want the race sound, go with your long tubes, no cats, thru a slp loudmouth. That will make all the noise you want.
Old Apr 16, 2008 | 06:43 PM
maverickmk's Avatar
that's what I'm thinking, screw the cam and open the exhaust up then drive it like a rental
Old Apr 16, 2008 | 06:52 PM
96capricemgr's Avatar
You can get good sound out of a smaller cam spec'd well as opposed to all the off the sheft stuff compromised because the manufacturers know customers are going to choose too big.
Far as the big block, driving my car has a friend convinced to take the 502 OUT of his first gen Camaro and put a LT1 in.
