LT1-Camaro and Impala
Old Jan 7, 2008 | 03:55 PM
1slow95Z-M6's Avatar
OK. So i bought an complete LT1 motor to build it for my 95 Z28...I dropped it off at the machine shop and they called and told me its an LT1from a impala..I know the heads are different but is there anything else different? Will it still drop in the same as my stock motor I have in there now?
Old Jan 7, 2008 | 04:48 PM
dangalla's Avatar
is it a 5.7l lt1 or a 4.3l baby lt1
Old Jan 7, 2008 | 04:52 PM
Lt1 5.7L 350
Old Jan 7, 2008 | 04:59 PM
dangalla's Avatar
Originally Posted by 1slow95Z-M6
Lt1 5.7L 350
what year is your car, what year is the motor from
some information in your sig would really help you out
Old Jan 7, 2008 | 06:10 PM
96capricemgr's Avatar
There was only one block casting for the Gen 2 motors, how much of that motor are you going too use? Pretty well everything that is the engine interchanges.
Can hit some snags with the damper hubs from different model cars or years, knock sensors changed based on years abnd the b-body got 2.
Seems you have a 95 and all the b-bodies got the vented opti like you have, 96s have a crank position sensor but if you used that timing cover just leave the sensor there too plug the hole.
The cams are a little milder in the b-body but with boltons and good tunes make similar power too the f-body.
Old Jan 8, 2008 | 08:57 AM
Dwayne:
Are the B-Body and F-Body oil pans the same? I realize he's probably swapping over the external components, like the pan and the accessory bracket, but was curious about the oil pan.
Old Jan 8, 2008 | 10:08 AM
1995 Z28 M6...I was told the motor was from a 94-95 Impala..
Old Jan 8, 2008 | 06:12 PM
Oil pan I am not sure.
I ended up wrenching on a trainwreck of a car that the guy had dropped in the whole f-body setup including accessories(accessories was a BAD idea cobbled is being polite). The f-body pan fit the b-body chassis fine but I never compared it too a known b-body pan and did not notice any obvious difference.
Seeing as the "f-body" pan fir the b-body I would guess they are the same, GM makes as few PN as possible right?
If someone has one a a shelf and wants to measure I can compare to one of my spares.
I know with aftermarket pans the b-body centerlink can be a clearance issue but that is usually deeper pans at the front.
bunker
Jan 30, 2016 08:09 PM
95chwagon
Oct 16, 2015 12:24 PM
Javi Fierros
Wheels and Tires
Jun 11, 2015 07:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
