LT1 Camaro dies intermittently
Old Jun 6, 2011 | 07:41 PM
Jason Lauzon's Avatar
97 Camaro will die and not restart once in a while, usually in the first 2-3 minutes of running. Fuel pump is good, has a newer msd coil. The engine will not even try to fire when I attempt to restart it. Then after a couple of minutes it will fire right back up and run like normal. I'm thinking it's ignition related and leaning towards the opti. Any thoughts?
Old Jun 6, 2011 | 07:49 PM
mrmint69's Avatar
Re: LT1 Camaro dies intermittently
My ignition switch got worn out and the car would die and sometimes it took time before restarting. I also had a starter that was so worn out that it would do what you are describing.
Old Jun 9, 2011 | 08:58 AM
It will still turn over after it stalls, it just shows no sign of wanting to fire. It'll turn over till the battery dies and will smell like fuel's comin out of the tailpipe, just no fire which leads me to no spark. Then after a couple of minutes it will start right up and run normal as soon as I touch the key.
Old Jun 9, 2011 | 10:54 AM
calaban's Avatar
Coil may be getting hot and then not firing properly. Once it cools back down a bit it starts working again.
Old Jun 9, 2011 | 02:01 PM
bw_hunter's Avatar
It's most likely the ICM which is mounted on the same bracket as the coil. You can have it tested at your local auto store. I'd recommend taking a heat gun or a hair dryer and testing it both at room temp and at an elevated temp.
If you do repalce the ICM don't forget the thermal transfer grease between it and the bracket.
Red Hawk 94
Mar 18, 2019 04:03 PM
Injuneer
Dec 15, 2014 09:36 AM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
Jul 4, 2005 05:00 PM
