Lt1 Cam
Old Mar 22, 2008 | 09:29 AM
kline454's Avatar
Lt1 Cam
Need help im putting together a 1995 camaro and im trying to find a cam that best fits my car and what im doing with it. The car is going to see the 1/4 mile drag strip more than anything, heres what i got 1995 camaro 3400lbs dry,th350 with trans brake,3.73 gear with 28 tire, the engine is a 383 11.7cr with srp forged pistons and egale 4340 crank and H beam rods. lt1 heads ported by Elliott portworks,the heads flow 287-201@600 and peaked 290-@630. aslo spraying a 200-250 shot of nitrous.My pcm limits my rpm to a max of 7200rpms,and my valve springs right now are only good for a 600 lift but i am willing to change them. i want a Hydraulic Roller cam i was running the cc306 does anyone know where i can have a custom grind done or have any ideas of what cam fits my car best? thanks KYLE.
Old Mar 22, 2008 | 12:12 PM
Stl94LT1's Avatar
Why not call LE and have him recommend a custom grind for your combination/needs?
Old Mar 22, 2008 | 02:20 PM
IROCThisZ28ForLife's Avatar
exactly
Old Mar 22, 2008 | 06:09 PM
kline454's Avatar
just trying to do some reseach before i get anything.
Old Mar 29, 2008 | 04:32 PM
understood man dont worry, but yeah call up thast your best bet
Old Mar 29, 2008 | 06:40 PM
rskrause's Avatar
Moderator
There are eleventy billion cam threads, you might want to read some of them. Or, either do as suggested and go with one of the grinds Bret specced out for Lloyd Elliot or get a "custom" (probably not needed for your application).
Rich
Old Mar 29, 2008 | 07:34 PM
kline454's Avatar
thanks i found some more info and im going with one of brets custom grinds.
rideordie
Nov 5, 2019 04:52 PM
oldschool
Feb 9, 2016 09:21 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Queens94z28
Nov 20, 2014 06:03 PM
