Changing Lt1 Head Gaskets
Old Mar 29, 2008 | 05:50 PM
ARZ28's Avatar
I Need To Do The Head Gaskets On My 94 Z28 And I Was Wondering If Anyone Had Some Advice That Would Make It Go Easier?also Does Anyone Now How I Get The Fuel Lines Disconnected From Top Of The Intake?thanks
Old Mar 29, 2008 | 05:52 PM
mdacton's Avatar
you need a quick dissconect tool for the fuel lines.
Just search the site...you will find what you need.
www.shbox.com should help too
Old Mar 29, 2008 | 07:51 PM
94zgreenmachine's Avatar
Originally Posted by ARZ28
I Need To Do The Head Gaskets On My 94 Z28.......... also Does Anyone Now How I Get The Fuel Lines Disconnected From Top Of The Intake?thanks
Autozone. You will need the 5/16th and 3/8th disconnect tool. You will slide the tool behind the fitting. Press forward slightly (like you are connecting the line) while you pull the tool away. It should come right off. DO NOT PULL on it HARD ! Sometimes just a slight wiggle is all that is needed. It has worked for me everytime. I just did it(again) 2 days ago.....motor is out....time for some more parts......
Old Mar 29, 2008 | 08:07 PM
dangalla's Avatar
spray down the exhaust manifold bolts with rust penitrant way in advance and keep doing it
Old Mar 29, 2008 | 08:38 PM
Jazsun's Avatar
Great use of capitalization!
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
