lt1 bolt ons and offs
Old Jul 27, 2008 | 02:43 PM
mr.green's Avatar
hey guys im wanting to make my 95 camaro faster....i run 8.9 in the eighth now with pacesetter lts, true duals, K@N cai , and a bbk underdrive pulley what are some other mods i can do to my car this is my daily driver and i work everyday so i need some things that can be done relatively quick any suggestions or combos that you guys have would help...thanks
Old Jul 27, 2008 | 05:09 PM
Throttle body coolant bypass.
Old Jul 27, 2008 | 09:18 PM
1SlowFormula's Avatar
I didn't see an air foil on the list???
Old Jul 28, 2008 | 11:01 AM
Severous01's Avatar
couldnt stand to lose a few hundred pounds either...
take out all the crap you never use...jack and spare, rear seats, carpet insulation, extra speakers (rears)
Old Jul 28, 2008 | 11:23 AM
ZL1modified's Avatar
more info about your car would be nice... a4 or m6? what gears? what was your 60' time?
lca's could probably help... delete ac and tcs...
Old Jul 28, 2008 | 11:40 AM
ShownomercyZ28's Avatar
How do you delete TCS?
Old Jul 28, 2008 | 03:51 PM
mr.green's Avatar
its an m6 with 3:42s i have the tire and the jack out already i have e3 plugs and taylor wires with an msd coil
Old Jul 28, 2008 | 09:24 PM
97SS0594's Avatar
ditch those junk *** plugs and run NGK tr6's
Old Jul 29, 2008 | 10:56 AM
Severous01's Avatar
another for the ngk's. ditch the 'special' plugs and the bosch +4 crap...and the +2 crap...and anything bosch for that matter......
some 3.73 gears wouldnt hurt at all...and wouldnt really hurt the fuel economy either.
Old Jul 29, 2008 | 06:53 PM
mr.green's Avatar
have you used the plugs before or is this just an opinion
Old Jul 29, 2008 | 11:53 PM
LJM97Z's Avatar
Getting good 60ft. times is the key, but having an M6 vs. A4 limits you to a great degree, the A4 cars run well with a stall/gears & stickies without too much worry from there 10 bolt., but us M6 guys have it harder, you want to go faster, but are 10 bolts don't like hard launches & the "shock" are stick car puts on it, the thing is, how fast do you want to go, if you cam it/gear it with other goodies, your putting more HP to a limited situation, your just going to spin any street tire more then before with added power & go knowwhere fast, this alone will **** you off, sure there are M6 guys doing the harder luanches with there geared 10 bolts on DRs & getting by with it, but MOST explode them in a hurry, then they rebuild them stronger, but they still break eventually, $$$ waisted IMO.
IMO, keep the 3.42s & leave the rearend stock (it will last longer), take some weight out, get it tuned & cammed, then get some MT DRs, keep your launches concervative (around 2500 rpms) & have fun, with the extra change, start piecing together a moser 9" with 4.11s, i do agree on the plugs, get a better set like the NGKs. You may hear a bunch of servivor stories on the 10 bolts, but if you look, you will see that most of them have an A4 tranny, sure, there going to survive ALOT longer.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
ddr698
Jan 9, 2015 10:05 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
jmzlt1
Mar 13, 2003 07:26 AM
WJH'sFormula
Jul 28, 2002 04:51 PM
