LT1 block VS reg 350 block
Old Jun 14, 2007 | 01:54 PM
speedracer69's Avatar
What is the main difference? Could you just slap all of the LT1 goodies on a reg 350block
Old Jun 14, 2007 | 01:58 PM
rskrause's Avatar
Moderator
No, the water passages in the deck surface are drilled differently to be compatible with the reverse cooling of the LT1 heads. Otherwise it is the same as other 1-pc. rear seal blocks.
Rich
Old Jun 14, 2007 | 02:00 PM
what about if the cast iron heads on the lt1(like) motor?
Old Jun 14, 2007 | 03:03 PM
They have the same water passage locations as the aluminum LT1 heads and are not directly compatible/interchangeable with the regular SBC.
Old Jun 14, 2007 | 06:14 PM
Depends what you mean by "goodies"..... the entire front of the block is different, requiring a different water pump, distributor, etc.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
sskevinm
Dec 18, 2014 11:16 AM
