LT1 AC delect pulley. Having a few problems with it.
Old Apr 17, 2013 | 10:36 AM
  #16
PWR SHFT's Avatar
Re: LT1 AC delect pulley. Having a few problems with it.
I have a brand new factory delete pulley if anyone is interested. It did not come with any hardware. PM me if interested.
Old Apr 17, 2013 | 08:33 PM
  #17
jer4251's Avatar
anyone know what size drill bit is needed to remove the threads? biggest I had was a 3/8's and didn't quite do the trick. still need bigger
Old Apr 18, 2013 | 10:44 AM
  #18
97 6SPEED Z's Avatar
Post Re: LT1 AC delect pulley. Having a few problems with it.
An english 3/8" converts to a metric 9.525mm, and, although I did my install quite a long time ago ....... I vagly do remember using a metric 10mm drill.
On another note, what is the length (height) of the shortest set of those bolt spacers? Again, as I recall I only used three (3) 1/8" thick washers to get very good pulley alignment, and ........... from your photos, it looks like the smallest of those bolt spacer sets is maybe, what a 1/2" plus ??? I really can't tell without some sort of ruler/scale in the picture.
Old Apr 18, 2013 | 04:49 PM
  #19
Kevin Blown 95 TA's Avatar
Those things look like split bushings that press fit into a hole.
Old Apr 27, 2013 | 04:09 PM
  #20
dzltek's Avatar
I just put one on that I got from ebay. I drilled the holes out with a 10mm bit also, and then I had to remove the pulley and put that spacer that came with the pulley behind it. After all said and done, belt went right back on perfectly. The bushings and bolts that I got didn't even fit the pulley or accessory bracket.
97z28k&N
Jan 9, 2015 04:58 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
Injuneer
Dec 15, 2014 09:36 AM
1LEThumper
Jul 14, 2003 12:45 PM
Krab
Aug 5, 2002 12:08 AM
