lt1
Old Jul 1, 2008 | 10:47 AM
Choppers's Avatar
lt1
I am looking at this car and the guy says that new ignition control moodule is bad and thats why the car won't turn over. i haven't physically looked at this car yet but am wandering if this is right. he says the car won't even turn over until you get the module. i thought they should still turn over correct. the car is a 95 and has 168,000 miles.
thanks
Old Jul 1, 2008 | 11:22 AM
seawolf06's Avatar
It should still turn over. The starter is connected directly to the battery.
It just won't run with a bad ICM.
Old Jul 1, 2008 | 11:34 AM
Jazsun's Avatar
If it doesn't turn over and the starter is good/has power than the engine is probably hydrolocked or damaged in some way. You can also try turning the crank pulley in the front manually using a long wrench/socket and see if it will budge. If it does, it could just be the starter/battery.
Old Jul 1, 2008 | 11:39 AM
Choppers's Avatar
so if i was to go over there and turn the crank with a wrench would i need to take anythjing off or could i just put the wrench on the crank?
Old Jul 1, 2008 | 12:27 PM
seawolf06's Avatar
You would need a socket and probably a long 1/2" drive wrench.
I don't remember what size head the stock bolt has.
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
