Lt1 1996 z28: Egr
Old Apr 2, 2016 | 02:41 PM
moose373's Avatar
Lt1 1996 z28: Egr
Gentlemen: (Especially Shoebox & Injuneer who have helped me before
I am new to my car and admit the car is very techy but I can not FIND MY EGR! Shoebox usually has pics but the ones I found dont tell me where it is. I know it is in back of engine but it seems nothing is accessible back there. So, how to get at it AFTER I find it? Thanks.
Old Apr 2, 2016 | 03:09 PM
Chimera96's Avatar
Re: Lt1 1996 z28: Egr
courtesy of shoebox site
Attached Thumbnails Lt1 1996 z28: Egr-egr1.jpg
Old Apr 2, 2016 | 03:13 PM
timnfxr's Avatar
What timing. I just relied to OP post on another forum with the same link. Post times probably identical.
Old Apr 2, 2016 | 07:07 PM
The minions are always working.
Old Apr 3, 2016 | 11:52 AM
moose373's Avatar
Can NOT thank you (& shoebox) enough.
Charlie
Old Apr 3, 2016 | 04:36 PM
STSturboLT1's Avatar
I replaced mine on my '96 a couple weeks ago because the one I used for my rebuild was used and turns out didn't close completely. Replacing it wasn't as bad as I expected, as long as you know what you're up against and can work by feel as opposed to sight. It probably only took me 15 minutes to replace.
Old Apr 3, 2016 | 04:57 PM
It's helpful to know there are two studs that hold the EGR valve to the back of the manifold. The nuts appear to be 1/2", but some claim they are metric. The valve may be hard to remove even after the nuts are removed from the studs. There is a metallic gasket that sticks solidly to the manifold and valve, given all the heat that it handles. A pry bar may be required.
The only connection to the EGR valve is the vacuum line, which pulls right off.
Old Apr 4, 2016 | 11:00 AM
moose373's Avatar
Very helpful; I thank you for the info.
Charlie
KYWes
Jun 14, 2022 06:52 AM
Gregdonna
Wheels and Tires
Jun 29, 2015 09:01 AM
Fatdog2
Pacific
May 26, 2015 01:25 PM
timmy39120
May 8, 2015 11:41 AM
supercharged94Z28
Feb 24, 2003 10:22 PM
