LT Headers adn O2 Compatibility
Old 11-21-2010, 07:00 PM
FastandBlue's Avatar
I was thinking about putting LT headers on the car to give it a little more power and make it easier to work in the frickin engine compartment (that last plug job had me fed up). What LTs would you recommend and how does this factor into the O2 sensors? What needs to be done to make sure these work? I hear you can't simply put LTs on these cars because of the O2 sensors. Input?
FastandBlue is offline
Old 11-21-2010, 09:06 PM
Re: LT Headers adn O2 Compatibility
The long tube headers have to have bungs for the pre-cat O2 sensors. As long as they have those, there is nothing preventing the use of long tubes, and the retention of the O2 sensors. Never heard anyone say you couldn't use long tubes because of the O2 sensors. You will need harness extensions for the sensors, since they move a bit further from the engine.
Your setup will not be emissions legal with long tubes, because they relocate the cat(s).
What makes you think any particular headers will make plug access easier? Many headers are worse then the stock manifolds.
Injuneer is offline
Old 11-21-2010, 10:37 PM
I was on a corvette forum which said that using certain LTs would give a little more access to the side of the engine. Why do I even visit any other forums??? :-/
So can I merely take the LTs on and off when I need to go through emission?
Old 11-21-2010, 10:49 PM
RamAir95TA's Avatar
If emissions are a concern, go with a shorty or mid-tube type header. You don't want to have to "merely" take them off when it's emissions time.
RamAir95TA is offline
Old 11-21-2010, 10:53 PM
Oh, gotcha. What about:
http://www.lmperformance.com/16363/2.html
Or
http://www.lmperformance.com/16361/2.html
Old 11-21-2010, 11:09 PM
97WS6SCharged's Avatar
You need to figure out if you have a single cat or dual cats on your car before you order the headers. I can tell you right now from the way those are designed you will not have better access to the plugs.
97WS6SCharged is offline
Old 11-22-2010, 11:47 AM
97Z28Muscle's Avatar
I don't know how the smog test is where you live is. But in the Phoenix,AZ area I live in this is what its like. If your car is a 96 or newer obd2 they don't even pop the hood or look underneath. No sniffers or synopsis. They plug into the obd2 port and see if there are any codes. No codes, you just passed smog. I used pacesetter long tubes with the air fittings on them and the o2 sensor bungalow. I cut the precat o2 sensor wires and extended them about a foot. Then just installed them. The spark plug/wire access is much better. The long tubes do perform better than manifolds.
97Z28Muscle is offline
13qtr
07-19-2015 05:30 PM
Strick
07-14-2015 07:28 AM
mrwz28
07-08-2015 09:11 PM
05-08-2015 11:30 AM
Quick Reply: LT Headers adn O2 Compatibility
