Lt-4 heads,cam and intake
Old Dec 10, 2008 | 06:52 PM
stanghater4lif93's Avatar
How much power do yall think this setup will give u?
Old Dec 10, 2008 | 07:03 PM
96capricemgr's Avatar
Ignorance is the ONLY reason to go with that combo today.
You can have your stock heads ported, get a matching cam and make as much at the wheels as the LT4 HOT package makes at the flywheel.
You only have 6 posts so obviously you are new, long as you asked before buying you are off to a good start.
The LT4 HOT package made 425 FLYWHEEL hp under ideal conditions.
Here is an example of making MORE power at the wheels with just heads and cam.
http://ls1tech.com/forums/lt1-lt4-mo...s-429rwhp.html
Old Dec 10, 2008 | 11:37 PM
93formula's Avatar
yeah go with a LE package you will be more then happy.
Old Dec 11, 2008 | 09:08 AM
DAVE00's Avatar
LE or AI packages. As both companies have proven themselves on the LT1 platform. Do a seach you will find TONS of stuff on both.
LeftoverChinese
Jan 14, 2024 03:03 PM
mikey4play
Mar 15, 2015 11:45 AM
Elcojoe
Nov 17, 2014 10:27 PM
Rich_z28
Aug 27, 2002 12:20 AM
