LT 1 Crank question
Old Jun 9, 2007 | 09:15 PM
jclark311's Avatar
LT 1 Crank question
Are all one piece seal cranks balanced the same, meaning nuetral balance on front/external balance on rear? Or is the LT1 crank specific to LT1?
Old Jun 11, 2007 | 08:33 AM
Dr. Teeth's Avatar
I have been looking into this now for a little while and I learned this: "the LT1 cranks are balanced internally on the front, EXTERNALLY on the back for use with a flywheel/flexplate that is balanced for the rear. It is possible to use a completely internally balanced crank like on the 1pc seal 350's but you need to either pop the weight off the flywheel/flexplate or rebalance the whole assembly."
Anyway, that's what I learned....
Old Jun 11, 2007 | 09:56 AM
rskrause's Avatar
Moderator
Of course they are not all the same. Why do you ask?
Rich
Old Jun 11, 2007 | 10:44 PM
jclark311's Avatar
I was asking because i am building a 355 lt1, the whole one peice seal thing is confusing, vortec is one peice but its balanced this way, lt1 is one piece, its balanced differently, yet the cranks are interchangeable. The only thing keeping me from finishing this project is the rotating assembly. I am going to just call Summit in the AM, and see what they have, i would like to use my flywheel, and damper, but if i need to buy new, i will.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
