Lowering compression?
Old Sep 25, 2006 | 03:39 PM
reamo04's Avatar
Alright guys, I am a novice at engine stuff (at least on v8s). I have edelbrock heads w/ 1.6RR and a cc306 cam waiting to go on. My problem is i have flat-top pistons, so right now id be at about 13.2:1 compression. The car is a DD so I'd like to get down to 11:1 or so. How can I go about doing this other than having the chambers milled out bigger. The chambers are 54CC.
Old Sep 25, 2006 | 05:14 PM
JustNO's Avatar
Re: Lowering compression?
Bigger chambers or Dished pistons
Are you sure about your CR ? (13.2:1)
Old Sep 25, 2006 | 06:00 PM
Originally Posted by JustNO
Smaller chambers or Dished pistons
You didn't really mean to say he needs smaller chambers to solve his SCR problem, did you?
How did you get to 13.2:1..... strictly because of the lack of valve reliefs? What are the other specs on the engine.... deck height, gasket thickness, gasket diameter, etc? Have you experienced problems with knock retard? Have you calculated the dynamic compression ratio?
Old Sep 25, 2006 | 07:31 PM
zjet's Avatar
A thicker head gasket will be easiest to drop the comp.With thta much you have to change pistons.Like mentioned up.
Old Sep 26, 2006 | 04:53 AM
JustNO's Avatar
opss mini tiny mistake (edited)
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
maverickmk
Sep 1, 2015 09:17 PM
Chevyguy358
Parts Wanted
Jul 20, 2015 07:42 PM
13qtr
Jul 19, 2015 05:30 PM
