low rpm miss
Old Apr 26, 2006 | 02:53 PM
bodydroppeddually's Avatar
low rpm miss
i have a 94 stock lt1 and at low rpm's the car backfires through the intake. it happens around 1200-1800. after that the car runs great. any help will help. thanks
Old Apr 26, 2006 | 04:23 PM
Re: low rpm miss
has anyone else had this problem?
Old Apr 26, 2006 | 07:39 PM
roguedriver's Avatar
Re: low rpm miss
How many miles are on the car and how many miles since the last plug, plug wire and opti change?
Ken R.
Old Apr 26, 2006 | 07:43 PM
87bandit's Avatar
Re: low rpm miss
I got the exact same problem right now
mine seems to be somewhat intermittent though
Old Apr 27, 2006 | 08:03 AM
Re: low rpm miss
The car has 61,000 on it and the opti was just changed.
Old Apr 27, 2006 | 10:44 AM
Re: low rpm miss
bump
Old Apr 27, 2006 | 10:55 AM
Red-LT1's Avatar
Re: low rpm miss
Most of the time I would say wires or plugs will do this. I had this problem for months before I noticed I had 2 really bad looking wires. I couldnt see they were burned through till I was replacing them.
Old Apr 27, 2006 | 11:43 AM
Re: low rpm miss
i will change them and see if that helps.
Old Apr 27, 2006 | 10:25 PM
Re: low rpm miss
If you have the original plugs in there, i would change them also. Does it miss under load, crusing or just all over? All your vacuum lines connected with no cuts or splits in them?
Ken R.
timmy39120
May 8, 2015 11:41 AM
Noenav
Apr 30, 2015 01:06 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
