low rpm bog only when its hot
Old Sep 7, 2008 | 03:17 PM
Geezer powered's Avatar
Cant really get my hand on it. Only when its hot out I get a intermitten bog only at low rpms, just below th 2k mark. New plugs, wires, fuel filter did nothign for the cure aswell as swapping the maf sensor. Maybe a heated soaked fuel pump.
also new cap.
Old Sep 7, 2008 | 10:48 PM
also new cap.
Are you asking about the 93 in your signature? How did you swap the MAF sensor on a 93?
Old Sep 7, 2008 | 11:12 PM
brentakabs's Avatar
i had the same problem and after droppin 1700 to fix all the problems it was still bogging down just when it got hotter then usual thats why i hollowed out the cat to free up the exhaust just a hair and now 94 z28 is running perfect, i bet your idle's probably a lil high or rough also right?
Old Sep 8, 2008 | 05:14 PM
no its on a 97
Old Sep 8, 2008 | 06:07 PM
no its on a 97
How do you expect to get help when you don't even bother to tell people what year car you are asking about?
timmy39120
May 8, 2015 11:41 AM
Noenav
Apr 30, 2015 01:06 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
TrouserSnake
Aug 7, 2002 12:43 PM
