Low Coolant Sensor
Low Coolant Sensor
I see where the sensor is located but it seems to be connected with a clip. How do you remove & clean it? Does the clip slide or is it fastened with a bolt?
Thanks.
Thanks.
The clip, most likely is just to hold the plug in the sensor. If you are having difficulty with the sensor showing bogus readings, you should probably just get another sensor.
The low coolant sensor is problematic on the Lt1s. JMHO
hahahahahah i just unplugged mine so its all good now
