Low Coolant Sensor
Old Oct 30, 2006 | 12:23 PM
Wild1's Avatar
Low Coolant Sensor
I see where the sensor is located but it seems to be connected with a clip. How do you remove & clean it? Does the clip slide or is it fastened with a bolt?
Thanks.
Old Oct 30, 2006 | 12:34 PM
BUBBA's Avatar
The clip, most likely is just to hold the plug in the sensor. If you are having difficulty with the sensor showing bogus readings, you should probably just get another sensor.
The low coolant sensor is problematic on the Lt1s. JMHO
Old Oct 30, 2006 | 01:10 PM
Tsar's Avatar
you think? hahahahahah i just unplugged mine so its all good now
Old Oct 30, 2006 | 03:07 PM
dre2013's Avatar
lol me too...i know my coolant isnt low and i watch my gauges constantly. my temp never even gets to the 1st line on the gauge. (160 tstat)
Old Oct 30, 2006 | 04:16 PM
Thanks.
Shoebox has your answer:
http://shbox.com/1/low_coolant2.jpg
blac94Z
Feb 15, 2021 09:43 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
91Bird305
Aug 8, 2002 12:36 AM
