Low Coolant light???? WTF????
Old Oct 8, 2003 | 09:42 AM
bandit1's Avatar
My low coolant light has came on the last 2 mornings when I started up my car. I know I have plent of coolant and the temps of the car seem to be normal. Is it a bad sensor or something????
Thanks,
Mike
Old Oct 8, 2003 | 09:43 AM
Type_O_Negative_1320's Avatar
Probably just a bad sensor. It's on the radiator underneath the fill neck...it's easier to get to if you take the battery out.
You can try cleaning it, but that didn't fix mine...I still need a new one.
Old Oct 8, 2003 | 09:47 AM
MaddHatter's Avatar
I'm just going to unplug mine, unless someone knows of an adverse effect it might have
bandit1's Avatar
Thanks alot for the quick reply. I'll for sure try it. I figured it was the sensor since it's been so tempermental (sp). Thanks again!
Later,
Mike
Old Oct 8, 2003 | 10:46 AM
fastcamz28's Avatar
Suggestion: change the sensor; it's a piece of cake. Located in the backside of the radiator, passenger side. Remove battery for easy access. Remove radiator cap, place rags below sensor location to prevent coolant from getting on Opti, disconnect sensor wire, remove old one (just slides out w/ a little effort and slight twisting back and forth to loosen-no screws,etc), slide new one in place, reconnect wire, remove rags, replace coolant & battery, and drive! Sensor available from any GM dealer, <$50.00. IMO, better safe than sorry.
Thanks!
calaban
May 18, 2020 06:43 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Jan 23, 2015 01:13 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Doug Harden
11
Jul 14, 2002 04:31 PM
