low compression 383 intended for boost, supercharger must wait
Old May 9, 2007 | 10:52 PM
92LT1RS's Avatar
I'm building up a 383 this summer that I ultimately intend to supercharge with a Procharger D-1 next summer. however, its going to be till next summer until I'll have the time/money to do the supercharger, so this summer I'm concentrating on building the engine. I'm planning for a 9:1 compression ratio to handle up to 15# of boost on pump gas.
Since the supercharger won't be coming for a while, should I do high compression pistons now and swap to dished when I add the blower, or build it once and deal with the low compression until then?
My planned build:
VRE 383 Speed pack (Dragonslayer crank, Compstar rods, Diamond pistons)
Ai 210cc Trickflows or Ai or LE3 LT4s (corresponding piston dish for chamber size)
Associated custom blower cam
36-40# injectors for now
Hawks long-tube headers
I know I'll be down on performance compared to a higher compression ratio N/A so I'll more than likely had some nitrous to the mix in the mean time until I do the supercharger.
Old May 9, 2007 | 11:08 PM
94NDTA's Avatar
Sounds like the exact same plan I have for next year.
Old May 10, 2007 | 01:47 AM
sssalah's Avatar
Changing the pistons later will require rebalancing the crank. So best bet would be to use some fun gas.
Old May 10, 2007 | 08:29 AM
92LT1RS's Avatar
then I'll let you know how it runs when I get it in
good point, I didn't think about that. low compression it is
Old May 10, 2007 | 08:31 AM
rskrause's Avatar
Moderator
You can get away with pistons that are up to ~30gms lighter (more on a big block) with no noticible effects. Some engine builders do this kind of overbalancing deliberately. Going heavier on an already balanced assembly is not a good idea. Though a small difference would be ok.
Rich
Old May 10, 2007 | 08:32 AM
Z-RATED94's Avatar
Agreed, plus there might be a slight difference in the size of the pistons. I think an engine builder checks the piston size before he puts the finishing touch on the bores, to get a perfect fit for whatever the application is.
Old May 10, 2007 | 08:40 AM
92LT1RS's Avatar
Rich
I just checked the Diamond catalog and the difference between a flat-top and the dished blower pistons is about 20grams heavier for the dished. answers that question then.
Old May 10, 2007 | 08:51 AM
rskrause's Avatar
Moderator
You might get away with that. I am not an expert in balancing - but I have done the lighter piston thing a few times times with no abnormal wear issues and no noticible difference in percieved vibration. What I have been told is that while that kind of overbalancing is ok, underbalancing (heavier piston) is more of a problem. The theory behind overbalancing is that on a blower motor, it decreases the force on the bearing as the piston approaches BDC. This makes sense, the piston is going down while the counterweight's net force is upward. A heavier piston would increase the load under the same circumstances. Of course, near TDC the forces are reversed, but since they are less there to begin with the overbalancing makes a certain amount of sense.
Rich
Old May 10, 2007 | 10:53 AM
92LT1RS's Avatar
since I'm ordering a balanced rotating assembly, I think I'll just leave it alone
Old May 11, 2007 | 01:45 PM
quickSS's Avatar
I think you made a good descision to build the blower motor now and run with it "all natural" while waiting for the future forced induction set up.
I just built an 8.6:1 F2 blower motor (383LT1) using Ai's top of the line heads/cam/valvetrain. The thing still makes monster torque and hp on an engine dyno (all natural). Maybe a bit sluggish at low rpm but you'll still have a hard time not noticing 500+ ft-lb of torque.
Heck, depending on the cam, maybe you can run junk gasoline "sans-blower'.
Karl Ellwein
Old May 11, 2007 | 03:39 PM
92LT1RS's Avatar
Karl, thanks for the reply, thats what I like to hear. Ai Trickflows is what I'm leaning to for the top end, although I won't be pushing quite the same amount of power through it as that F2 will
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
drptop70ss
Mar 26, 2015 01:50 AM
