Low battery voltage on dash gauge.
Old Mar 6, 2009 | 01:03 PM
derrickgott007's Avatar
I've got a 97 LT1 A4 AUTO and the battery gauge sometimes goes into the red. It's a new battery with clean terminals and wires. I check on the fuse links on the left and get 12.9 to 13.5 volts. and when the gauge dips down low i can turn on my headlights and it'll bring it up. Did I lose a diode in the alternator? what could this be?
Old Mar 6, 2009 | 01:20 PM
canuck94z28's Avatar
I had the same problem but then i have a March u.d pulley.I then ordered a o.d alt one and it did bring up the volts and never goes into the red area.Also chk your belt for tightness,etc as this can affect things.
Old Mar 6, 2009 | 01:42 PM
n2ceptor's Avatar
At normal operating idle, the voltage at the battery should be around 13.8~14.2 volts... If not then the alternator might be going out...
nosliw
Apr 26, 2015 02:13 PM
eanhl2004
Apr 4, 2015 12:01 PM
silvermansteve
Mar 4, 2015 05:02 PM
Gtpguy
Jan 26, 2015 04:50 PM
Hot Rod Hawk
Aug 15, 2002 10:47 PM
