loudest intake setup?
Old Apr 28, 2006 | 10:14 PM
  #16
JoeliusZ28's Avatar
Re: loudest intake setup?
Originally Posted by 94EvilZ28
I got a 52mm tb and SLP dual tube cold air setup...and mine sucks pretty loud...what SLP did you have? I love mine...and a good serup if you ask me.
i have the dual tube. Like i said, it pretty much just "sips" at the initial opening of the throttle.
i also just remembered i still havent deleted that stupid donkey dong. Im gonna try that tomorrow i think.
Old Apr 28, 2006 | 10:16 PM
  #17
JoeliusZ28's Avatar
Originally Posted by 96ssblack
Ok my air intake on my car sounds like a vacum cleaner and here is what i did to make it sound that way. First get ram air because you already have the ss hood. Then get a high flow air filter like a k/n or a airhog and put that in the ram air box. Then get rid of that stock intake elbow because that thing will kill your sound, and do not replace it with a rubber one because a metal will have a better sound. Then get 58mm tb and port the intake if you like and bam you will have that air intake scream. Trust me this works because I use the same setup on my car and it sounds like a darn vacum cleaner is under the hood. Do not descreen your Maf those wires are very sensitive and that screen is in there to protect it.
would a 58mm tb hurt mileage at all? Ill consider porting the intake when i take it off to do the cam a long time from now.
Old Apr 28, 2006 | 10:27 PM
  #18
onebadponcho's Avatar
I'm sure that's most of your "problem". You probably already know, but that stupid donkey dong plastic piece in the stock intake elbow is a silencer. Either plug it, or get a 1LE, Vortech, Trick Flow - whatever elbow. If you have a TB airfoil, that probably makes things a bit quieter if anything, but an airfoil improves airflow. Louder isn't necessarily better. With that being said, my setup = K&N FIPK - Stock MAF w/screen - 1LE elbow - 52mm TB w/airfoil doesn't "whistle" or anything. However, you can definitely tell air is movin' pretty well in there.
Old Apr 28, 2006 | 10:48 PM
  #19
NYC32798's Avatar
I just put in my slp intake the other day and I hardly hear a difference. If someone drove in that car for the first time, they would never know it was there. The loudest normal intake i've ever heard in a car (excluding blowers) is in my maxima. That thing is LOUD. Can't hear it when driving normal but at WOT, it gets loud as hell. I wouldn't doubt the intake is louder on that car than an exhaust would be. Everytime I race someone they ask me what the hell you got in that thing? I expected the intake in the camaro to be a little louder than it was. I was also looking for a nice sound but I didn't get it. Oh well. Time for cut-outs.
Old Apr 29, 2006 | 10:08 PM
  #20
JoeliusZ28's Avatar
well i just finished deleting the donkey dong, ill see how it is tomorrow morning when the bugs arent out.
Old Apr 29, 2006 | 10:11 PM
  #21
jamilz28's Avatar
what did you use to delete it?
Old Apr 29, 2006 | 11:51 PM
  #22
JoeliusZ28's Avatar
bottom of a shampoo bottle. I RTV'd it to make sure it sealed good.
Old Apr 30, 2006 | 03:22 PM
  #23
JoeliusZ28's Avatar
test drove it today... theres definitely a little more noise there, but its difficult to hear it over the exhaust anyway, even with the cutout closed.
Old Apr 30, 2006 | 05:48 PM
  #24
Ray86IROC's Avatar
When I put my Moroso cold air on briefly before my catback I believe it increased the sound of wind or sucking a little, but it wasn't tooo noticeable. After the catback and especially gutted cat and headers I don't really hear intake noises much.
Main thing mine does is everytime I turn the car off just as it quits there is a quite noticeable short distinct "exhale" sound from the filter/intake area that started w/ the Moroso. It's pretty weird, does everyone's do that?
I certainly wouldn't change your intake around just for sound even if some of them were a little different.
Old Apr 30, 2006 | 10:33 PM
  #25
JoeliusZ28's Avatar
yep, mine does that too
Old May 1, 2006 | 06:21 PM
  #26
jamilz28's Avatar
i deleted it and it didnt help
DirtyDaveW
Mar 15, 2015 07:01 PM
alex5366
Feb 17, 2015 08:12 PM
squinn
Aug 4, 2002 01:06 PM
jdohman
Jul 22, 2002 06:01 PM
