Loud ticking driving me crazy.
Old Dec 26, 2007 | 04:17 PM
  #46
mobleman's Avatar
Well lets just say that my CM guideplates don't do as good a job of aligning the rockers to the valve stems and that the GM guideplates (would have to go look on Shoebox's website to find the PN) are supposed to do a better job. Agreed that there will always be side to side contact but a better alignment may help remove some of the noise. (I'm not saying it will, just planning on finding out ) Misaligned rockers can translate into out of plane forces between the pushrods and the guideplates.
As far as the noise being attributable to the pushrod/lifter interface.. I'd say that is just one of the potential causes. Some people found similar noises caused by contact between the roller rockers and their valve covers for example.
Originally Posted by dangalla
no. its not. there will always be side-to-side contact and there should not be noise from that. its when the pushrod smacks the bottom that a noise is created, and you can only imagine how it effects the geometry and valve events
and there is no stock guideplates for a lt1
Old Dec 26, 2007 | 04:43 PM
  #47
dangalla's Avatar
alot of people have been having problems with the gmpp guideplates your talking about not being hardened and wearing very fast
your best bet is a set of the isky adjustable's or if need be modify the trick flows
Old Dec 26, 2007 | 10:11 PM
  #48
ssean92's Avatar
Originally Posted by NukeFPE
Motor Mounts? My 94 Z did this to me & drove me totally insane Took me forever to find it. Lashed my lifters, changed timing chain & gears, etc...The right side mount was bad. Here's what my car would do & how to check for: The motor mount is caged in a rubber bushing ~ where the bolt passes through looks like an "I " beam on its side. When the car was first started, everything was fine, as it warmed up, the rubber heated & "Tap, Tap, Tap" started, sounded just like a stuck lifter, or maybe, maybe, a rod knock. Hotter it got, the more it tapped. How I found it ~ Had the car up on 4 jack stands, crawled under & had the girlfriend start & put in gear (automatic). (I know ~ you are not supposed to do this, but I was at my wits end...) The torque then started the tapping. Stuck a screwdriver between the metal/rubber in the motor mount and discovered the source of the tapping.
I might have to look at this. HUMMMMMMMMM
Old Dec 26, 2007 | 10:46 PM
  #49
thewhite97z28's Avatar
Sparkplug
I had the same problem, it got worst and worst it happen when I raced an EVO 4 times and won 4 times when it ran on 7 cylinders LOL.
Old Dec 27, 2007 | 03:16 PM
  #50
HardcoreRM125's Avatar
Never thought to check the motor mounts ... Something to look into. I think once I get the car in the garage for the winter, im gonna pull the covers and check for guideplate wear. If thats a no go, im going to go ahead and play with the motor mounts. The car runs strong so ....
Old Dec 28, 2007 | 08:46 AM
  #51
NukeFPE's Avatar
Motor Mounts
Like I said ~ this drove me crazy. Check them when the car is hot & the rubber in the mount is soft. If you look at the design, you will see the metal center section is mounted in the rubber bushing and allows for the engine movement (twist/torque). There are two "ears" on the center section that limit the amount of rotation. When the rubber wears out, the metal section twists & starts tapping on the mount (metal to metal).
Good luck!
Old Dec 29, 2008 | 11:03 AM
  #52
dookie454's Avatar
Originally Posted by camaro81
Here's a video I took before I took the motor out for a second time.
http://s6.photobucket.com/albums/y21...boveengine.flv
Here's the video from the dyno, you can't hear anything once it's reved up.
http://s6.photobucket.com/albums/y21...rstDynoRun.flv
I'll tell you for sure that's not lifters/rockers, it sounds much deeper than valvetrain. Maybe it's the quality of the video but that' much deeper than valvetrain.
737drivr
Feb 20, 2015 11:54 AM
importkiller94
Jan 17, 2015 09:03 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
Jessie4tin
Jan 7, 2015 08:53 AM
squarehead
Nov 21, 2014 08:02 PM
