Is a loud fuel pump bad?
Old Apr 25, 2004 | 12:53 AM
96redformula7's Avatar
I just noticed since I change my optispark that my fuel pump is damn loud as ****, makes an air pressure kind of noise? Is this normal or a sign mine might be getting ready to go?
Old Apr 25, 2004 | 02:10 AM
jdhommert's Avatar
I've got a buddy with a 3.4,and his was going out,and he said the louder it got, it seemed to get worse.
So i would guess yours is on the way out.
Heard is a MAJOR PITA though on a Fbody.
Old Apr 25, 2004 | 02:29 AM
Greasepunk's Avatar
yeah that's a sign of a fuel pump goin bad, but doesn't mean it's on it's last leg.
you're talkin about the noise sounds like when you turn your key over to run but not start it, that 'whine'?
Old Apr 25, 2004 | 02:32 AM
97WS6SCharged's Avatar
You'd freak if you heard my T-rex pump. It's not bad, just extremely loud.
Old Apr 25, 2004 | 02:42 AM
Tony Danza's Avatar
thats interesting. Now that this is mentioned and i think about it, the only time i ever noticed the mechanical whine noise it makes was only after i knew the pump was/is starting to crap it self. I guess this is true, i never heard of this symptom before, only the others, and thats how i already know its diein.
Old Apr 25, 2004 | 02:57 AM
Greasepunk's Avatar
Yeah it's a pretty common symptom and about the most accurate from what I've read.
Old Apr 25, 2004 | 03:54 AM
hsyr's Avatar
My fuel pump does it too, and 20,000 miles later, it still works! I'd say there is nothing to worry about.
Old Apr 25, 2004 | 02:23 PM
Tony Danza's Avatar
Do you mean yours does the noise when you turn the ignition on?
everyone's does that, but the combination of that exagerated priming noise and the low mechanincal buzz/whine at idle with my windows up is what i think gives clout that this is a symptom.
adding to that what Greasepunk just mentioned, it seems that its true.
Old Apr 25, 2004 | 03:59 PM
GreenDemon's Avatar
Mine makes an annoying noise too, and it's highly suspect.
I'm not talking about that high pitched noise that is common with these cars (sounds kind of like a that noise from a tv?), but a lower pitched noise that will drop a little if there is a sudden load on the electical system (fans).
Some people say that it's just the way they are though, some are louder than others. Since I've tested mine and it builds pressure fairly slowly, I'm going to replace it anyway. But I won't have results for a few months yet.
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
