Loss Of Power
Old May 13, 2008 | 06:41 PM
tcb2008's Avatar
Loss Of Power
did anyone have this problem when car is cold it runs fine when it's hot it hesitates i changed egr valve 95 lti did plugs and wires
Old May 13, 2008 | 10:25 PM
DrRuckus13's Avatar
Your issue sounds fairly common with the bad opti threads sorry
Old May 13, 2008 | 11:45 PM
Fatdog2's Avatar
Might spray some throttle body approved carb cleaner on the mass air sensor.Ever so gently (car not running).Hope this helps.
Old May 14, 2008 | 06:42 AM
bombebomb's Avatar
Correct me if im wrong but I dont think EGR effects performance.
Old May 14, 2008 | 07:08 AM
derekderek's Avatar
Maybe the o2's going bad running in closed loop drives fine. But once it warms upp and goes to open loop starts dumping to much fuel and fouling out plugs. Its worth a shot anyways put a scanner on it see what it says.
Derek
Old May 14, 2008 | 07:42 AM
Nitelite's Avatar
Derek
When the car warms up, is when it goes into closed loop.
Old May 14, 2008 | 02:43 PM
WestCoast96Z28's Avatar
Had that similar issue...for me..it was a bad O2. Easier to check that then to replace your opti. Are you getting any codes?
Old May 14, 2008 | 03:42 PM
cidkane's Avatar
I got the same problem now. Checked the opti, seemed fine. Still the same problem when I reinstalled it. I had no doubt it was opti some ignition problems, but I don't know anymore. Got a code, but can't read it, since it's some problems with the obd...
Old May 14, 2008 | 09:01 PM
Dave1980's Avatar
also check the ICM for failure upon heat soak.
Old May 15, 2008 | 12:30 AM
derekderek's Avatar
Oppps sorry!! I got them backwards. But you get the just of it. Thanks for the correction.
Old May 15, 2008 | 05:56 AM
1982z28with18s's Avatar
Definitely get a scanner on it, it's most likely one of the o2's has gone bad.
warmeck
May 7, 2015 02:10 PM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
thenewkid
Nov 27, 2014 09:41 AM
XtremeLt1
Sep 13, 2002 08:50 PM
slothgrant
Aug 22, 2002 03:01 PM
