loss of power
Old May 4, 2004 | 02:24 AM
96birdlt1's Avatar
loss of power
I feel that my car has lost alot of power as of the past few months. Gas mmilage is a little worse than it has been. the car has 120,000+ miles on it. Sometimes the idle feels like it has a little miss to it,just a little bit, and not that often, maybe one stop out of 75 stops.
the last tune up was about 70,000 miles.
Never changed the opti.
Dirty injectors?
Bad opti?
Bad plugs?
Knock retarding the timing?
rockers?
Any ideas? I don't know where to start.
Old May 4, 2004 | 02:29 AM
BiGGinZ's Avatar
Could be any of those. Or O2's or an exhaust leak. You should do plugs, wires, opti, and injectors just because it has been that long.
Old May 4, 2004 | 02:36 AM
96birdlt1's Avatar
My A/F guage is reading lean as well. If that helps any.
Old May 4, 2004 | 02:39 AM
BiGGinZ's Avatar
It could be plugged injectors. I have never delt with them but I would imagine it would make it run lean.
Old May 4, 2004 | 04:13 AM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Oh lord...... Where to start.... Well start with the cheapest, Plugs and wires. I recommend Taylor 8mm or Moroso. I use NGK plugs with no problems. Then on to O2's. 30 dollars each i think. AC delco. Still no change then go with opti an coil change. Both very simple. I guess you could also go with a fuel injection clean from any car fixing place or it DEFINITELY could be your fuel filter(which is cheap from autozone) Thats all for now.... Start replacing is all i can say....... You got a lot fo miles on your car. I have 70K on my car and i have already replaced all of these i have stated so i guess it is your time
Chris
warmeck
May 7, 2015 02:10 PM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
thenewkid
Nov 27, 2014 09:41 AM
XtremeLt1
Sep 13, 2002 08:50 PM
slothgrant
Aug 22, 2002 03:01 PM
