parts questions on rebuild
Old May 1, 2004 | 10:50 PM
NEOS97SS's Avatar
i spun my 7 & 8 rod bearings so im rebuilding
im starting a list of stuff i need and p/n's
if any one can help or can think of anything im forgetting or has any ideas please throw them at me. i need recomendations on brands and the best places to buy pricewise. thanks
im going with a new stock crank and rods
planning on using clevite H main, rod and cam bearings
speed pro moly rings
im getting the block ball honed, cleaned and prepped with the new cam bearings installed and new freeze plugs
.039 or .036(cant remember) head gaskets
felpro rebuild gasket kit
ported and polished intake and heads milled for flatness
high volume oil pump
new head bolts
thats all i can think of off hand anything else????
Old May 2, 2004 | 12:19 AM
97WS6SCharged's Avatar
For the price of the stock crank and rods, you can probably find something aftermarket that's a bit stronger. Also, for a NA motor I'd probably stick with a stock oil pump instead of the high volume unless you intend to run a larger oil pan. And invest in a good set of ARP head bolts, rod bolts, and main studs.
And have it all balanced while your at it.
Old May 2, 2004 | 05:23 PM
NEOS97SS's Avatar
im gettin the rods and crank off a friend who went to a 383, and im gettin it at a price i cant pass up so im stickin with stock, and why not get a high vol. pump.
Old May 2, 2004 | 05:31 PM
Dave88LX's Avatar
You're missing a few items:
http://paradox.shacknet.nu/dave88lx/formula/383/383.htm
Old May 4, 2004 | 12:02 AM
TCAL95Z's Avatar
Ya,
There is nothing wrong with using your friends parts. Just make sure they don't need any work. Check on what it's going to take to have the rods resized ect. You still might be better off going with some Eagle I beams
You should go over that list it's the most complete list I've ever seen.
I'm building my own and the little stuff really adds up
Dave,
How did you get AI to port your heads for only $1,000?
Thats more than a deal
Old May 4, 2004 | 12:08 AM
Ok, you said new so I thought you meant brand new. My bad. Main reason I don't like to use a high volume oil pump with a stock pan is that you can possibly suck the pan dry at high RPM. A stock LT1 oil pump is quite adequate for a street car.
Old May 4, 2004 | 01:15 AM
Dave88LX's Avatar
Originally posted by TCAL95Z
Dave,
That's misleading, sorry. The left column is what I owe, the right column is what I've paid. So, I've paid him $1000 so far, I still owe what's in the left column...
$800 more went out to him today. Shouldn't owe him much more after this.
Old May 4, 2004 | 04:19 AM
rskrause's Avatar
Moderator
I am using a stock oil pump with a 6,800rpm redline and over 800rwhp. High voume pump may suck the sump dry and it takes extra hp to turn it. So why bother?
Rich Krause
Noenav
Mar 1, 2019 07:38 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
