Looking for info on SLP SFC
Old Nov 29, 2003 | 08:08 AM
Mr.Whitey's Avatar
I can't seem to find the info from my SLP bolt-on SFCs and I need to know the torque specs for the four g-load brace bolts. I checked the GM service manual and the Haynes but couldn't find the numbers.
TIA
Old Nov 29, 2003 | 09:27 AM
lastlaf's Avatar
I just went and found my instructions for the SFC's. They don't mention any torque specs in them at all other than to say to, "tighten all bolts." All I did with my g-load bolts was snug them up; I don't think they can take alot of torque. The rear LCA bolts are the important ones, and you should have that spec in your book. All the other ones are normally tightened anywhere from 60- 70 ft/lbs. You should check them after a while, but mine have never come loose after a few years of being on.
Old Nov 29, 2003 | 09:49 AM
Mr.Whitey's Avatar
I had to remove the brace in order to get the y-pipe out. Thanks for the help.
Xiantyl
Jul 21, 2015 05:42 AM
colts0455
Jul 20, 2015 09:52 AM
Dark Zeiro
Jul 19, 2015 08:25 AM
asilomar244
Jul 12, 2015 05:53 AM
