Looking for a good off road 3' Y pipe?
Old Feb 1, 2006 | 09:50 PM
FNKWICKZ-28's Avatar
I have a 97 Trans am, I just bought some Long tube pacesetter headers for it, now i need to get an off road Y pipe 3 inch. Just wondering what u guys run and the quality certain companies have.
thanks dave,
Old Feb 2, 2006 | 11:25 AM
96flame's Avatar
Re: Looking for a good off road 3' Y pipe?
The pacesetter Y-pipe fits pretty good and tucks up underneath nicely
Old Feb 2, 2006 | 11:33 AM
2000GTP's Avatar
Yeah, you can't go wrong with the pacesetter y-pipe. Also, the pacesetter headers are a slip-fit style so your choices of y-pipes are limited to pacesetter's very own unless you decide to weld flanges onto your headers.
Old Feb 2, 2006 | 01:55 PM
1995greenTA's Avatar
I would suggest having flanges welded up to your headers with whatever y-pipe you decide to get. If you do not use three bolt flanges, definetly do not use the regular horseshoe style clamps.
I have the pacesetter y pipe with the pacesetter lt's and it was a 5 minute job to install it. Very nice fit.
Old Feb 2, 2006 | 02:06 PM
I burn rice too's Avatar
Get the Pace Setter Y-pipe and then use the stainless band clamps. That way if you need to pull the pipe apart it will come off with ease. I think I paid $7.00 for each one over at Napa.
Old Feb 2, 2006 | 04:02 PM
thanks alot guys
Old Feb 3, 2006 | 12:02 AM
matt65's Avatar
I have the pacesetter LT and ORY. I had planned to use the stainless band clamps, ended up welding to get rid of leaks at the bands.
Old Feb 3, 2006 | 03:59 AM
scottslt1z28's Avatar
i just used the pacesetter y-pipe and the bolts that came with it
I made sure the y-pip was on the header really good then put the Ubolt connectors on and tightened them as hard as i could..........needless to say i tried to take one side off, and i tightened it so hard that it bent the y-pipe down on the header so i dont think it will ever just slide off..............however i have still yet to determine if i have a leak or not
but i think im just gonna take it to a exhaust shop and have them weld it up nicely because as it sits now i dont think it will come off anyways.........and if i ever take it out, i will go true duals so i can just cut the y-pipe off.
jayblev95
East South Central
Feb 15, 2015 02:26 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
jayblev95
Jan 6, 2015 11:52 AM
Fbodfather
25
Jun 21, 2002 04:12 PM
