cam dowel pin length?
Old Feb 2, 2006 | 08:30 PM
Black6spdZ's Avatar
I have a cam out of my 96 lt1 that a buddy of mine wants tobuy and he has a 94 what is the difference in the dowel pin lengths? Also what is the easiest way to change them?
Scott
Old Feb 2, 2006 | 09:15 PM
rcmtby11's Avatar
Re: cam dowel pin length?
i dont know the exact lengths, but i know the cars with a vented opti havea shorter dowel. all i did was tap mine in a little with a hammer. it only needs to stick out as far as the cam sprocket is thick. hope that helps and maybe someone can give you more details.
Old Feb 2, 2006 | 10:31 PM
No...non-vented optis use the shorter dowel pin.
Old Feb 3, 2006 | 06:21 AM
Loadre's Avatar
Or if you don't like hammering on your cam, poke a hole through a t shirt and push the dowel pin through, using the t shirt to cover up the rest of the cam. Then break out the dremel.
Old Feb 3, 2006 | 06:46 AM
rcmtby11's Avatar
ok, by vented i mean the one with 3 vent holes in the aluminum casing. they look like vents to me, and i had to shorten the dowel pin. eh
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
oldschool
Feb 9, 2016 09:21 PM
Midnight_Z
Parts Wanted
Apr 3, 2015 12:46 AM
chuyz28
Feb 19, 2015 12:50 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
