Looking for a good off road 3' Y pipe?
I have a 97 Trans am, I just bought some Long tube pacesetter headers for it, now i need to get an off road Y pipe 3 inch. Just wondering what u guys run and the quality certain companies have.
thanks dave,
thanks dave,
Re: Looking for a good off road 3' Y pipe?
Yeah, you can't go wrong with the pacesetter y-pipe. Also, the pacesetter headers are a slip-fit style so your choices of y-pipes are limited to pacesetter's very own unless you decide to weld flanges onto your headers.
I would suggest having flanges welded up to your headers with whatever y-pipe you decide to get. If you do not use three bolt flanges, definetly do not use the regular horseshoe style clamps.
I have the pacesetter y pipe with the pacesetter lt's and it was a 5 minute job to install it. Very nice fit.
Get the Pace Setter Y-pipe and then use the stainless band clamps. That way if you need to pull the pipe apart it will come off with ease. I think I paid $7.00 for each one over at Napa.
i just used the pacesetter y-pipe and the bolts that came with it
I made sure the y-pip was on the header really good then put the Ubolt connectors on and tightened them as hard as i could..........needless to say i tried to take one side off, and i tightened it so hard that it bent the y-pipe down on the header so i dont think it will ever just slide off..............however i have still yet to determine if i have a leak or not
but i think im just gonna take it to a exhaust shop and have them weld it up nicely because as it sits now i dont think it will come off anyways.........and if i ever take it out, i will go true duals so i can just cut the y-pipe off.
Fbodfather
25
Jun 21, 2002 04:12 PM
