looking to get new crankshaft need help!!
Old Sep 30, 2007 | 07:47 AM
93camarochrisz28's Avatar
i am looking to get a new crankshaft and would like to know what would be alittle better than stock but not going to be over $300.00 any help would be great thanks
Old Sep 30, 2007 | 11:36 AM
speed_demon24's Avatar
None will be better than stock for $300.
Old Sep 30, 2007 | 11:53 AM
96capricemgr's Avatar
agreed, I might even call the $450 stuff a tossup compared to stock.
You want better for sure I would start looking at the $650 or so Compstar stuff.
People ASSume stock means weak and they would be wrong.
On the plus side any aftermarket is probably going to be lighter, the stocker is like 62lbs.
Old Sep 30, 2007 | 12:13 PM
is it a must to get a lighter one how much does it help ? should i just save and get a lighter one or would a like stock one be ok
Old Sep 30, 2007 | 03:05 PM
A "lite weight" aftermarket will be 42-48lbs, and cost extra, the normal aftermarket crank will be say 52-58lbs., a stocker as I said is like 62lbs.
Just going aftermarket and you will get a liter one without going "lite weight".
Why are you worried about going aftermatrket? The stocker is quite good.
Old Sep 30, 2007 | 03:14 PM
Why do you feel you need a new crankshaft?
Old Sep 30, 2007 | 03:42 PM
ok what happend is i bought a crank off eBAY bc my old one what not straigth or i was told that it was not and then i bought one off ebay i asked the guy if it was for a 93 to 97 lt1 and he said yes and i put in in my rebuild and all that stuff and i go to put the timming cover on and the the part that comes out is that you put the blancer on is smaller than the hole on the thimmimg chain cover so i think it is a crank for a older lt1
Old Sep 30, 2007 | 07:13 PM
Kevin Blown 95 TA's Avatar
you know it seals on the balancer right? not the crankshaft.
The timing gear fit on the shaft right?
Old Sep 30, 2007 | 09:11 PM
i relized that alittle bit ago but mmy crank has a key in it and my hub dont
Old Sep 30, 2007 | 09:13 PM
The stock LT1 crankshaft has a key cut into it for the damper hub. But the stock LT1 damper hubs do not have a keyway or a key.
Old Sep 30, 2007 | 11:20 PM
WS6T3RROR's Avatar
Yeah the stock key on an lt1 crank ends right where the crank gear ends for the timing set. if your crank has a key in it just give it a couple of sharp raps with a hammer to unseat it and then pry the key out. OR just get your hub keyed, or buy an ati.
Old Oct 1, 2007 | 04:34 PM
thank you guy all soo much saved me alot of $ best camaro site
Slayer
Aug 17, 2015 03:55 PM
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
mrwz28
Jul 8, 2015 09:11 PM
SergheiS
Jul 5, 2015 03:27 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
