A look at my opti and the problem I've been chasing
Old Sep 11, 2009 | 03:40 PM
SmokeyBlaZe's Avatar
A look at my opti
pulled all the plugs and plug wires off and this is what I found when I removed the coil wire from the opti. Any idea what the red and black plastic is from?
and the rest of this came out of the coil wire.
Old Sep 11, 2009 | 03:53 PM
So should I go with an MSD cap and rotor or Accell or an opti rebuild kit from thepartsladi? Money is tight.
Old Sep 11, 2009 | 03:59 PM
rclearyiii's Avatar
Get the kit from the parts ladi
Old Sep 11, 2009 | 05:39 PM
Rebuild kit has been ordered.
http://cgi.ebay.com/ebaymotors/GM-OP...4506.m20.l1116
Along with a new set of Jegs plug wires.
Old Sep 11, 2009 | 07:49 PM
rclearyiii's Avatar
Good choice Smokey..I am sure you will be pleased with the outcome.
Old Sep 11, 2009 | 08:53 PM
so what do you think the red plastic is from?
Old Sep 11, 2009 | 10:00 PM
rclearyiii's Avatar
I honestly do not have any idea what the plastic is from. I could only guess. If you find out...please let us know. thanks..
Old Sep 11, 2009 | 10:30 PM
It could be what is left of old wire insulation. Does it really matter if you are replacing it?
Old Sep 12, 2009 | 10:12 AM
rangers458's Avatar
Make sure you get a deep well 1/4 drive E4 torx socket....
Old Sep 14, 2009 | 02:05 AM
Im gonna try and use the screw off of the tb plate , is that the only socket i need?
Old Sep 15, 2009 | 07:39 PM
Got my cap & rotor today along with the plug wires.
Now if I only knew where to start... By the way the #5 plug with shorty headers is a pain in the ***. I broke 3 new ones before i got it in there and then the last turn I heard that familar sound of the plug cracking yet again. Doesn't feel cracked and im not about to pull it out to check it either. It almost seems like it would be easier to just remove the headers just to change out the plugs. So where should I start , draining coolant and removing hoses?
Old Sep 16, 2009 | 01:39 PM
Do I have to remove the line going to the p/s pulley or can i just remove the two bolts and be able to move it out of the way enough?
Old Sep 16, 2009 | 01:54 PM
96SSIndeed's Avatar
Not sure what the red was but i know when i pulled my opti to change it. It had an msd cap and rotor on it. There was red pieces on the inside from where the rotor was hitting the body of the opti
Old Sep 16, 2009 | 08:32 PM
onefastmx5's Avatar
Pull the 2 bolts that mount the PS to the bracket and move it out of the way.
Old Sep 17, 2009 | 01:02 PM
I'm having trouble getting the harmonic balancer off, I have a 3 finger puller but the bolts it came with dont match up with the ones i took out , and those are too thick to go through the puller, any ideas? Also I've got two felpro waterpump gaskets , what kind of sealant do I need and where do I apply it?
