Longer rocker arm studs for guideplates
Old Mar 26, 2021 | 08:27 PM
WhiteWS6's Avatar
Buddy of mine is thinking about upgrading to a 1.6RR (Comp Mag 3/8") on his LT1, they are non-self aligning therefore he should get a set of guide plates for them. He is going with the Trickflow TFS-30400623-8 guide plates. I read somewhere previously that you need a longer length stud due to the length used by the guide plate. What rocker arm studs are people using for this application?
Thanks in advance
Old Mar 27, 2021 | 12:48 AM
siguy's Avatar
Re: Longer rocker arm studs for guideplates
I would contact http://elliottsportworks.com/ (Lloyd Elliott) he can guide you in the right direction
Old Mar 27, 2021 | 08:41 AM
DrewHMS97SS's Avatar
Also, if buying new rocker arms, always upgrade to 7/16 studs and arms.
Old Mar 27, 2021 | 09:33 AM
WhiteWS6's Avatar
Do the 3/8" studs tend to have issues? Or does it just make for a more 'stable' valvetrain?
Old Mar 27, 2021 | 12:32 PM
Significantly more stable valve train at rpm. Check out Engine Masters, they did a comparison with clear valve covers.
Old Mar 27, 2021 | 12:35 PM
The 7/16” rocker studs are more stable. Higher valve spring pressure, more aggressive lobe ramps, higher lift, and higher RPM may make the 3/8” studs unstable. Cheap insurance. Alternatively, you could use a stud made of stronger steel (e.g. chrome moly)
Interesting notes on stud selection:
https://arp-bolts.com/kits/product.php?PL=49
Old Mar 27, 2021 | 01:27 PM
WhiteWS6's Avatar
Great info, I'll have him keep that in mind.
z28guy30
Apr 23, 2008 01:19 AM
MadMike 97 Z28
Apr 15, 2008 11:14 PM
94_camm
Parts Wanted
Dec 16, 2006 11:16 AM
93camaroLT1
Parts Wanted
May 16, 2005 04:34 PM
96z
Jan 29, 2003 08:35 PM
