Long tubes or shorties?
Old Nov 11, 2005 | 12:34 PM
  #46
GnarlyZ28's Avatar
Re: Long tubes or shorties?
Jet hots seem prety decent.
What headers would the best for hooking up the emission equipment and catalytic converters?
One more question, does anyone know how much hp/torque the stock cats rob? just curious.
Old Nov 11, 2005 | 12:42 PM
  #47
2000GTP's Avatar
I believe both Pacesetter and Jet-hot offer LTs with emissions equipment. I know Pacesetter does for sure. The LTs and ORY will be 3 inches, so your stock cat. is smaller and will not fit unless you modified it to do so, which is not worth it. You can get a high-flow 3" cat. for around 50.00-60.00 bucks.
Old Nov 11, 2005 | 01:42 PM
  #48
JakeRobb's Avatar
Super Moderator
You're not asking the right question.
Exhaust components don't "rob" the car of power. They set an upper limit on power. An engine is an air pump, and the exhaust is the output. A restrictive exhaust limits the output.
That said, I have no idea what the upper limit would be on the stock cats, but I'd guess that it's probably close to 400rwhp.
Old Nov 11, 2005 | 03:38 PM
  #49
GnarlyZ28's Avatar
So are you saying that having that cats. does not cause any power loss under 400rwhp?
Old Nov 11, 2005 | 04:52 PM
  #50
Joe 1320's Avatar
Originally Posted by Bersaglieri
I and about 98% of everyone else would take LT's over shorties anyday including sunday. Everyone I have ever met or talked to who switched from shorties to longtubes have seen significant improvement. I guess those are all flukes
What other mods did you have to trap 107mph or was it just the magical shorties?
-Dustin-
Since you used this: I'm not even going to repond the sarcasm.
Old Nov 11, 2005 | 04:54 PM
  #51
Joe 1320's Avatar
Originally Posted by fireman
Ran 13.3 @ 106mph(2.0 60') with hooker shorties, CAI, and 4.10s. I believe you gain ahelluvalot more going from manifolds to shorties than from shorties to longtubes.
I installed my coated pacesetter longtubes last week...
Agreed..... especially when you ditch the factory Y pipe which sucks at best. My ceramic SLP shorties, random tech dual cat Y pipe and mufflex 4" flow just fine. No ground clearance problems either.
Old Nov 11, 2005 | 07:00 PM
  #52
ABA383's Avatar
Joe 1320...
I'm with you on the shorties to an extent...1 3/4" shorties are a whole different animal over 1 5/8"..I run the LPE 1 3/4" shorties and Random Y with gutted CAT and my time is in my sig. I am going to try the Kooks LTs 1 3/4 stepped to 1 7/8 with the 3" Y. I waited until a company came out with LTs that have no ground clearance issues and still allowed the use of my Spohn TA which is set up for shorties..The Kooks are supposed to fit this application and should flow a little more. I'm at the point where every tenth is starting to cost some $$$ and I'm hoping for a couple with this new set up...I'm taking a $1200 risk that the new stuff will be better..we'll see. That being said I'm still a huge fan of Big tube shorties for a number of reasons. I even think that Fred (moderator) usually chimes in here with people he knows running shorties and flying...
For most people large tube shorties will work great...
--Alan
Old Nov 11, 2005 | 07:08 PM
  #53
Joe 1320's Avatar
Originally Posted by ABA383
Joe 1320...
Don't get me wrong, I do like big tube long headers. However, with my 2" drop, I wouldn't have a prayer in running those. Actually, it's not the headers I would worry about. The collectors aren't really that low. It's the Y pipe that gives most people the clearance issues. I see exactly where you are at and it does make perfect sense.
Old Nov 14, 2005 | 04:53 PM
  #54
blkchevyz's Avatar
whats wrong with edelbrock headers? i gained 3 mph and 4 tenths with them on a pretty much stock car? that a damn good improvement.
after i put in the hot cam in i dynoed 344.
well everyone was telling me that my headers were sucking up so much power... so i spent a grand on some flps... and dynoed 344
well worth the money
now that i've gone alot farther with the car im happy i went with them. but wasnt worth it on a daily driver.
so with that said, shorties are a great buy for someone on a budget looking to not loose any ground clearence
Old Nov 14, 2005 | 08:14 PM
  #55
Bersaglieri's Avatar
Do you happen to have both dyno graphs? I'd like to see them.
-Dustin-
Old Nov 14, 2005 | 08:43 PM
  #56
TJ Chapman's Avatar
Hold on, we're getting off track. Gnarly Z28: do you have to pass emissions? If not don't waste $$ on cats. Just run LTs and a 3" y-pipe no cats and 02 simulators, if you feel the police around you are basically cool. If you do have to pass emissions, just get an exhaust shop to weld in some 3" high flow cats into your LT y-pipe. Unless you want to drop your car, LT shouldn't cause ground clearance issues. If you don't have to pass a visual or sniff test emissions test, then get headers with no AIR or EGR, 3" y-pipe, no cats, no rear 02 sensors. Then get someone like MadZ28 to delete the EGR systems and such from your computer, eliminating trouble lights, and adding even more power in other ways (around $125 for tune, well worth it) This will be the cheapest way. around $400 headers, $120 y-pipe, $80 02 sims, then $125 tune (which is more HP gain than just exhaust)
shorties, and a stock y-pipe and cats will give you almost no noticable power gain as far as you can tell. (I'm sure the dyno, maybe even the track will read some gain, but not just your gut feeling)
Old Nov 14, 2005 | 09:55 PM
  #57
NeverEverSatisfied's Avatar
Originally Posted by Cmr0z28
Pacesetter LT's. See times in sig. Very easy installation, high quality, cheap price. Had them almost 2 years now and the coating has held up extremely well.
That could be your problem running those Pacesetters why you are stuck in the 13's. Customs are the way to go and then get them Jet Hot Coated...
Old Nov 15, 2005 | 09:50 AM
  #58
blkchevyz's Avatar
-Dustin-
i'll look, but that was like 4 years ago
Old Nov 15, 2005 | 11:55 AM
  #59
89385formula's Avatar
I hope I am misunderstanding what you wrote there. Your saying that his pacesetter LT's are keeping him in the 13's? If so you are very ignorant...no scratch that your a jackass. If not than I appologize for name calling. There are enough header options for 99% of the people out here. There is no need for custom headers unless you want a custom turbo setup, or you run an out of the ordinary head setup...ie..SB2.2, 15*, 18*. There are shorties to fit the bill for almost anybodies budget, LT's for guys running 9's and people on tight budgets. Primaries that are from 1 1/2-1 7/8" and your gonna say that you need custom headers.
Old Nov 15, 2005 | 03:27 PM
  #60
GnarlyZ28's Avatar
I wasn't really planning on turning my car into a full blown racer. I just wanted some extra power for on the street, i am also on a tight budget. If i were to go with a set of shorties and the stock dual cat y-pipe with my current mods would there be a somewhat noticeable increase in hp or torque?
