Location of sensor plug for ram air box??
Old Oct 5, 2007 | 03:26 AM
GASH1313's Avatar
were is theLocation of sensor plug on the wire harness that plugs into the intake box for ram air box! I can't seem to find it! It's a 97 formula if that helps
Old Oct 5, 2007 | 05:19 AM
As far at the physical loction of the harness connector, look at Shoebox's harness photo, which has all the sensors labled. Its for a 95, but the location in the harness will be the same. The IAT sensor wire comes out of the bundle that runs down the passenger side of the intake manifold, then to the front of the engine.
http://shbox.com/1/harness.htm
Old Oct 5, 2007 | 06:15 AM
GASH1313's Avatar
thanks!
Old Oct 6, 2007 | 04:42 AM
GASH1313's Avatar
Wink
how will the car run without this hooked up? Or I should ask what problems can this cause? thanks again!
Old Oct 6, 2007 | 10:46 AM
Without the IAT sensor plugged into the harness, you should have an SES light and a trouble code. You may have some issues at cold start. You may see a loss of 3* of ignition timing.
Why do you not want to hook it up?
Old Oct 9, 2007 | 02:00 AM
GASH1313's Avatar
I was just wondering what it may cause the car to do when not conected. I did find it and hooked it up and it idles smoother now, it was hidding on top of my water pump! Now that I got that taken care of my throw out fork has gainedsome play! So no onto that problem, I have to pay somone to take care of that becaue I'm still recovering from my shoulder surgury.I just can't wait to get this thing 100% and get this thing into at least low 11's on motor then spray the garden hose at it! Thanks for all your input Injuneer!
Old Oct 9, 2007 | 01:22 PM
If your IAT sensor (not just the empty harness connector) was laying on the water pump housing, there's a good chance you were losing some timing. If you do not want to put the sensor in the air box, just plug the sensor into the harness, and stick it somehwere that is will not be affected by engine heat. All the PCM is looking for is some indication that A) the sensor is there, and B) an indication of the actual inlet air temp. Don't forget to plug up the hole in the air box, so you don't pull unfiltered hot air into the box.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
LT14LIFE
Feb 9, 2015 09:35 PM
rjc1629
Jan 27, 2015 10:46 AM
TitoPR221
Parts Wanted
Jan 10, 2015 09:21 AM
