lil question
Old Mar 1, 2005 | 07:02 PM
ericz28w's Avatar
lil question
im haveing a hell of a time with the evap purge solinoid, it throws a codes, and keeps getting full of lil chunks of charcoal, replaced the solinoid and still fill up with charcoal?? is my canister bad, or something else bad??
Old Mar 1, 2005 | 07:20 PM
Re: lil question
If you had an occurance with the old solenoid that caused charcoal to be pulled into it, you would have needed to purge the hose from the canister before putting on the new solenoid. Otherwise the new solenoid would get clogged from the old residue.
Old Mar 1, 2005 | 08:06 PM
ericz28w's Avatar
Re: lil question
could my canister be bad? or u think just clean the line out and i should be ok like u said (shoebox)
Old Mar 1, 2005 | 08:15 PM
OBE1 95Z28's Avatar
Re: lil question
How did charcoal get in the lines in the first place...I'd suspect that the charcoal canister is bad (only source for charcoal).
Old Mar 1, 2005 | 10:16 PM
Re: lil question
If the old EVAP solenoid was hanging open and allowing full vacuum at times to the canister, then it will suck charcoal out of it. I don't exacly know how to tell if a canister is bad.
Old Mar 2, 2005 | 10:42 AM
ShawnMacAnanny's Avatar
Re: lil question
not to hijack the thread, but if you remove the EGR and AIR can you remove the EVAP canister and solenoid too? I'm not exactly sure what they do other than expel fuel vapor or something, but is that important?
Old Mar 2, 2005 | 11:17 AM
Re: lil question
The canister captures fuel vapors to they don't enter the environment. The purge solenoid opens to allow the collected fuel vapor to be burned in your engine, as part of the normal fuel calculation. In effect, it reduces fuel odor at the rear of your car, and should actually improve fuel mileage a tiny bit. Does not hurt performance in any way, unless you manage to saturate the canister with fuel.
Old Mar 2, 2005 | 11:20 AM
Re: lil question
Oh ok thanks. I'm just always looking to remove unnescessary things like ABS, AIR, EGR, the donkey dong, and stuff like that.
rednekrocketeer
Apr 20, 2015 09:17 AM
94Z28LS1toLT1
Feb 26, 2015 07:47 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
