Lifting motor to install header question
Old May 24, 2003 | 10:18 AM
5thCamaro's Avatar
The passenger side header will not go in with out tilting one side if the engine. My question is it easier to unbolt the mount from the engine or the mount from the frame?
Old May 24, 2003 | 10:38 AM
thewinner's Avatar
i found it easier to take the 3 bolts out that go into the block.
Old May 24, 2003 | 11:38 AM
Fastbird93's Avatar
What kind of headers are they? With some creative maneuvering, you should be able to get anything but Hooker Long Tubes in without unbolting the engine.
Old May 24, 2003 | 11:45 AM
SplitFire's Avatar
I installed my jethot lt's without lifting the motor. I think you could do it without as long as you have the car high enough. I measured mine, and the the car was, i think, 3ft 2in off the ground. Went it very easy.
Old May 24, 2003 | 12:26 PM
Dave88LX's Avatar
I unbolted mine from the block as well.
Old May 24, 2003 | 05:43 PM
5thCamaro's Avatar
Thanks for the help, I unbolted from the block. The only pain was getting the bolt holes to line up when reinstalling the mount.
LeftoverChinese
Jan 14, 2024 03:03 PM
Noenav
Mar 1, 2019 07:38 AM
1775.Z28
Jan 11, 2015 10:51 AM
hotrodyou1
Dec 20, 2014 10:05 PM
