Lifting motor to install header question
The passenger side header will not go in with out tilting one side if the engine. My question is it easier to unbolt the mount from the engine or the mount from the frame?
I installed my jethot lt's without lifting the motor. I think you could do it without as long as you have the car high enough. I measured mine, and the the car was, i think, 3ft 2in off the ground. Went it very easy.
hotrodyou1
Dec 20, 2014 10:05 PM
