Lifters and pushrod install
Old May 4, 2014 | 02:36 PM
  #16
pizzi-man's Avatar
Re: Lifters and pushrod install
What I said as far as the adjustment of rockers is method 2 on Shoe Boxes site. and earlier when I quoted from GM is #1 on Shoe Boxes site.
Old May 4, 2014 | 03:41 PM
  #17
Chet1185's Avatar
The motor was just cleaned and bored .030. The cylinder walls were pitted due to rust. Heads were not touch and i bought stock replacement head gaskets from autozone. The lifters that were installed were used from my previous motor. I don't know if there's 1 sticking or what. The car drives great but I want to get this fixed before something bad happens.
When i first adjusted them, I used the method in the manual. I didn't feel comfortable with it so I adjusted them with it running. The noise isn't constant, so i have no idea. I can do alot of things but I'm just not comfortable doing this....
Sent from my LG-LS860 using Tapatalk
Old May 4, 2014 | 06:04 PM
  #18
slick1hunting's Avatar
Yes sir. I was mearly saying I find #3 to be the easiest to not make a mistake and given there is also the engine running method this gives the op 4 choices to see if he feels more comfortable with doing one. Not at all sayi g anythi g you said was wrong or in error other than a rebuilt motor or any changes in valvetrain including lifters could cause a change or a need for different size lifters. Its my understanding that the most common reason for collapsed lifters is mismatched valvetrain components and the noise the op is concerned about may be pointing to this as valvelash, spring rates and pressures and pushrod length all have important parts to play in things working well.
Old May 5, 2014 | 07:50 AM
  #19
pizzi-man's Avatar
Chet, did you rule out an exhaust leak between the head and the exhaust manifold? A leak there will sound like a ticking and many have confused this with a lifter going bad.
Old May 5, 2014 | 12:10 PM
  #20
Chet1185's Avatar
An exhaust leak would be constant right? I did just get my long tubes on with copper gaskets. So we will see soon.
Old May 5, 2014 | 01:02 PM
  #21
Exhaust leak "tick" will vary with throttle position, engine load, and engine temperature.
Old May 5, 2014 | 01:07 PM
  #22
Chimera96's Avatar
often as the engine gets hotter exhaust leaks between manifold and head or even further downstream can get quieter as the metals expand....but the leak is still there, just not sometimes as noticeable.
if you have a scan tool showing one bank is running rich, that is often due to a exhaust leak and the 02's see more air so PCM commands more fuel to be dumped
I have always had good luck with the FelPro exhaust manifold gaskets with headers
Nov 18, 2023 07:21 PM
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
alex5366
Feb 17, 2015 08:12 PM
