Tri Y headers
Old May 3, 2014 | 11:00 PM
TT350's Avatar
Tri Y headers
Anyone ever run them?
Old May 4, 2014 | 10:57 AM
Re: Tri Y headers
Interesting reading from Kooks Headers:
Some facts about Tri-Y Headers vs 4 into 1's
Old May 4, 2014 | 11:44 AM
TT350's Avatar
Re: Tri Y headers
I find it odd that they would just start a thread on why 4 into 1 are better than tri Y's
There must be some competition in the C7 header market.
I found this. Pfadt Tri-Y Long Tube Headers - C6 Corvette
2 Vengeance Racing C7 builds using tri Y's
I think Kooks is doing damage control.
Vengeance Racing C7 Stingray Build Thread
Insane C6Z idle - Vengeance Racing "Sumbich" camshaft - 592-rwhp
Old May 5, 2014 | 11:09 AM
TT350's Avatar
Re: Tri Y headers
Here is a dyno test where tri Y's are blowing 4 into 1 out of the water.
Exhaust Header Dyno Test - Circle Track Magazine
Just wondering if anyone of you LT1 veterans know of a set being used on a LT1 F-Body
or have first hand experience with them.
Old May 5, 2014 | 01:14 PM
Re: Tri Y headers
Did you read this part of the Kooks post:
Tri-Y Headers or 3-collector headers are designed for maximum performance for a specific engine combination, desired engine RPM, race track, etc. For a Tri-Y header to have the proper effect the cylinder firing order must be properly paired so that the next firing cylinder is separated. Sequential pairing is optimum, example the LT-1 firing order is 1-8-7-2-6-5-4-3 so pairing of the 1 & 5 and 3 & 7 cylinders on the passenger side and the 2 & 4 and 6 & 8 cylinders on the driver’s side would be the proper sequence. You also need to have the proper primary size for the engine displacement and application. The collectors also need specific convergent angles (7-20 degrees) for optimum efficiency and cannot be a random bend angle. We have seen horsepower and torque numbers dramatically affected by these angles in Tri-Y headers. In our testing we have found the primary head pipes (First Section) must be between 17” – 21” in length for proper pulse scavenging, anything more than this has shown no increase in performance.
The data we have collected over the years proves the Tri-Y design does have advantages in race applications with the right vehicle and the right engine combination on the right track. Most professional teams will have several sets of headers and engine combinations for different tracks and conditions.
Did you read this part of the article you linked:
Conclusion Here comes the tough part. Unlike the previous tests where we were able to separate oil pan and rocker arm performance from the rest of the engine package, header performance is critically dependent upon the design and performance of the rest of your intake and exhaust system. For example, had we used a single-plane intake manifold instead of our Weiand dual-plane intake, the results could have been completely different. The same holds true if we had used a different set of cylinder heads, camshaft, and even the length of the exhaust pipe after the header collectors.
So, while we cannot unequivocally say that Tri-Y headers are the best design for your race engine, we can say that small changes in the way a set of headers are constructed can have a significant effect on your engine's performance. In fact, finding the set of the headers that best compliments your engine package can significantly improve power.
Old May 5, 2014 | 02:41 PM
lt1-xjs's Avatar
Re: Tri Y headers
The B body guys have used them for years.
alex5366
Exhaust System
Mar 8, 2015 11:28 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
Head Hunter
Aug 29, 2002 07:21 AM
sleeperZ96BT
Aug 20, 2002 09:07 PM
