Lifter Tick... uh oh..!! help
Old Nov 15, 2006 | 08:40 PM
  #16
Gun5's Avatar
reamo, as in hiding the noise not fixing the lifter tick my mechanic says they will still quit.. if I put lucas in and the noise stops and its running like top (does now after 4 minute heat up) it should be fine right?
thanks
Old Nov 15, 2006 | 11:23 PM
  #17
HardcoreRM125's Avatar
Put it in and see what happens. What do you have to loose. Just dont pound on the car until you have money for new lifters.
Old Nov 16, 2006 | 12:32 AM
  #18
Gun5's Avatar
if the sound goes away I still cant pound on it??so basicaly i should just replace the lifters instead of even trying to quiet it because knowing me I will if the sound goes away.. hell it still runs like a raped ape right now
Old Nov 16, 2006 | 07:05 AM
  #19
rob97ss's Avatar
Check out www.bobistheoilguy.com for some info on oil additives,With 600 miles on the motor i would guess you just had it rebuilt,why did you cheap out on new lifters?
Old Nov 16, 2006 | 07:46 AM
  #20
Gun5's Avatar
usualy u can reuse hydro lifters just fine... noone brought up getting new lifters either i asked many times what should I put new in it.. i dont have unlimited $$$.. i saw some kits on summit (comp cam) they are like $68 for a set of 16 hydro lifters thats a good deal i imagine?\
"Competition Cams # 812-16 Hydraulic Lifters for 1955 thru 1995 Small Block Chevy 283, 327,350,383,400 and 1958 thru 1990 Big Block Chevy"
Old Nov 16, 2006 | 03:51 PM
  #21
Gun5's Avatar
to the top.....
Old Nov 16, 2006 | 04:04 PM
  #22
reamo04's Avatar
thanks
most of the time, the ticking lifter just indicates that it is getting cold, and not sealing, the lucas oil helps swell the seals to make them seal. I have been running lucas oil for about 200 miles now, and my lifter NEVER ticks anymore, my motor has 145k on it, and it see's 7k RPM's daily. I change my oil about every 2k now with this many miles, and having it see high RPMs regularly, but i wouldn't think its necessary to change that often, I just like to be real preventative.
Old Nov 16, 2006 | 07:58 PM
  #23
Gun5's Avatar
the rockers and valves are still moving like the lifters are working 100% so i dont understand for the noise my mechanic says they will just get worse and fail... i'd fix it myself not like he would get any money for fixing it but if i can avoid it with lucas oil ill take that route and take the hail dmg out of my car
Old Nov 16, 2006 | 08:04 PM
  #24
reamo04's Avatar
your rockers and valves still work fine because your lifter is fine, its nothing to worry about just add lucas oil in
what you have is a bleeding lifter, meaning its not sealing because its getting cold and the oil is leaving the lifter, once it warms up, it seals again and is fine. youre fine running it the way it is, just don't beat on it until that lifter seals (normally around 170-180*)
you can run it how it is, and let the oil warm up and seal the lifter that way, but you will have to do this everytime, or add lucas oil and be done with it
Old Nov 17, 2006 | 09:29 AM
  #25
Gun5's Avatar
ya i mean thats what happens is once it hits 170 bye bye tick.. my car runs extremely cool so it stays at 170 usualy (electric pump, water wetter) the only hard driving i did with it ticking is going up to 2-3k rpms (backing up and going on my street/hill) because of the big stall
Old Nov 17, 2006 | 09:40 PM
  #26
Gun5's Avatar
well hes still doing lash called another lt1 guy out double checked each others work... he says its coming from the top of the damn heads aka springs.. they arnt cracked or broke he said maybe the head got hot and height of the spring or the geomtry or something is off... and is happening now due to it not being set currectly
remember only
700-800 miles on this motor guys
Old Jan 1, 2007 | 02:42 AM
  #27
Gun5's Avatar
Well all the valve trains been gone through we put new springs due to the old ones being for a solid roller... got new comp cam posi locks since the stock nuts backed off as soon as you tightened them and when we put those posi locks on about 3-4 studs on each side are bent... so all the problems have come out now the heads will be 100% and the car will be back on the street this week /knock on wood
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
FryedClutch
Sep 1, 2015 08:24 AM
