Do i need bigger injector?
Old Dec 31, 2006 | 01:45 AM
always faster's Avatar
Well im getting ready to put my new lt4 engine in my car.Its a stock one(330hp) with all the bolts ons(see sig).Add to this a tune and a asp 23% underdrive damper.
Im hoping for around 350whp.
Do i need some 30lb injector or my stocker are gonna be fine?
Old Dec 31, 2006 | 02:09 AM
sbs's Avatar
sbs
If this is the factory crate LT4 you have referred to in previous posts, then it has 28#, so 30# would be an insignificant change.
No car needs bigger injectors if all you have is bolt ons.
You're also not going to see anywhere near 350RWHP. LT4 vettes make around that with bolt ons and a cam.
Old Dec 31, 2006 | 02:21 AM
Yep its a crate engine but it doesnt come with injector.So right now all i have is the stock lt1 one wich are smaller then 28lbs.
So i guess some 30lbs would be good...right?
Old Dec 31, 2006 | 03:12 AM
sbs's Avatar
sbs
30# would be fine, but probably not on your stock LT1 tune.
(Referring to this thread: http://web.camaross.com/forums/showthread.php?t=492620)
Since you have to buy injectors anyway, you might consider going a little bigger to accommodate possible future mods.
Old Dec 31, 2006 | 03:39 AM
Yes i finally decide to order a tune from madz28 since it will be needed no mather what
And i think that 30 or 32 would be ok because the reason i will be running the engine in is stock form is to have a fun and reliable ride for a couple of years.
Old Jan 1, 2007 | 03:52 AM
I finally bought some 32lbs,i got them brand new for a very fair price.
It will be more then enough for the setup and will give me a little room for improving later
93 RedBird
Nov 15, 2015 08:24 AM
form94
Sep 23, 2015 07:30 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
95craz28
11
Sep 12, 2015 07:47 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
